how to get rid of the probed dumping non-probe mode error?
25 Oct 2025 08:21 - 25 Oct 2025 13:26 #337132 by abs32
Colleagues, there is Probe. And there is a constantly appearing error
probe tripped during non-probe mode
To combat this error, I specified the following in the configuration file -
loadrt select8 count=1
addf select8.0 servo-thread
net probe-in select8.0.enable
net motion-mode motion.motion-type select8.0.sel
net probesel select8.0.out5 motion.probe-input
The error frequency is immediately sync. However, with such a conciguration, the g38.4 and g38.5 command does not work
When you enter (midi mode) the g38.5 command (options), nothing happens. And when you enter the g48.4 command (parameters), nothing happens either, but an error message appears - probe is already clear when starting g38.4 or g38.5 move, while in fact the sensor is in the "contact is" state and this is visible with the eyes - contact with the body is and the contact LED is lit.
This error disappears and the g38.4 + g38.5 commands are executed normally if "those" entries in the configuration file are deleted.
The question is: how to get rid of the probed dumping non-probe mode error?
Last edit: 25 Oct 2025 13:26 by abs32.
25 Oct 2025 08:25 #337133 by Aciera
25 Oct 2025 10:58 - 25 Oct 2025 11:00 #337141 by abs32
Thank you, I'll try
Last edit: 25 Oct 2025 11:00 by abs32.
25 Oct 2025 13:42 - 26 Oct 2025 08:15 #337151 by abs32
v2.8.4
from what has been said here -
forum.linuxcnc.org/38-general-linuxcnc-q...ue-with-g38-5#336766
I inserted the following lines into my hal -
#Negate Encoder Position
setp mult2.2.in0 -1.0
setp comp.0.in0 0.005 # Threshold value for encoder
net enable-probe <= motion.digital-out-03 => and2.1.in1
# Encoder position and comparator
net negated-encoder-out <= mult2.2.out
net negated-encoder-out comp.0.in1 # Connect to comparator input
net encoder-threshold-met <= comp.0.out => and2.1.in0
# AND logic to trigger only during probing motion
net probe-trigger and2.1.out motion.probe-input
when I start, I get an error -
parameter or pi 'mult2.2.in0' not found
from what has been said here - www.forum.linuxcnc.org/38-general-linuxc...dlock?start=0#332412
setp flipflop.0.set FALSE
setp flipflop.0.data TRUE
net probepin parport.0.pin-13-in-not => flipflop.0.clk
net probereset motion.digital-out-00 => flipflop.0.reset
net probefiltered flipflop.0.out => motion.probe-input parport.0.pin-01-out
parameter or pi 'flipflop.0.set' not found
What am I doing wrong?
Last edit: 26 Oct 2025 08:15 by abs32.
25 Oct 2025 14:12 #337154 by Aciera
Maybe you forgot the 'loadrt ...' and 'addf ...' lines for those components in your hal?
25 Oct 2025 14:25 - 25 Oct 2025 14:31 #337156 by abs32
yes.
in the second option it was necessary to add -
loadrt flipflop count=2
addf flipflop.0 servo-thread
addf flipflop.1 servo-thread
LNCNC started without errors.
However, the scanning program worked crookedly - the probe reached the workpiece, rested on it and went to the side.
but it’s not yet possible to launch the first option; I don’t know which loadrt + addf are needed for and2.1
I found about others -
loadrt mult2 count=3
addf mult2.2 servo-thread
loadrt comp count=1
addf comp.0 servo-thread
Last edit: 25 Oct 2025 14:31 by abs32.
25 Oct 2025 14:38 - 25 Oct 2025 14:42 #337158 by abs32
This option completely ignores the sensor operation G38.3 F550 Z0!
My simple task is to find the bottom when the sensor is triggered, to move away from the found bottom without triggering an error "non-probe mode error"
Last edit: 25 Oct 2025 14:42 by abs32.
25 Oct 2025 14:58 - 25 Oct 2025 15:12 #337161 by abs32
if -
##Negate Encoder Position
loadrt comp count=1
loadrt and2 count=2
addf and2.1 servo-thread
then, when the command is executed -
M64 P3
G38.3 F15 Z0
the machine does not respond to the sensor.
And in the usual configuration -
        net probe-in        <= parport.0.pin-13-in-not
        net probe-in => motion.probe-input
the sensor is triggered, the machine understands this, but sometimes there is an error "non-probe mode"
Last edit: 25 Oct 2025 15:12 by abs32.
26 Oct 2025 09:55 #337205 by andypugh
Are you really using 2.8.4 rather than 2.9.4?
This problem was fixed in 2.9.5. Do you have a good reason not to update?
(rather than 2.9.5 you should probably use 2.9.7. See:
forum.linuxcnc.org/21-axis/57364-axis-co...-9-6?start=10#336658 )
26 Oct 2025 10:19 #337208 by Aciera
@abs32
Please don't post the same questions in different threads.
Time to create page: 0.340 seconds
