Hard stop homing
25 Dec 2025 03:15 #340478 by tommylight
Replied by tommylight on topic Hard stop homing
OK since this has gotten some interest, there are two methods of using hard stops for homing without messing with the drives at all, for DC brushed motors:
1. using hal sensors wired to inputs (be it Mesa or Pico or parallel), more windings around the sensor = more sensitive
2. using REED switches wired to inputs ...., again more windings = more sensitive
There are two types of hal sensors, those with variable output and the on/off type, latter is easier to use for this use case.
Sensors should be wound with only one motor wire, not both.
The following user(s) said Thank You: NWE
25 Dec 2025 04:17 #340482 by NWE
Replied by NWE on topic Hard stop homing
I can't wait to try that. I have tons of cheap inductive proximity sensors (well, more like a couple handfuls). Coil one motor power lead around it. Great idea. Cheap and simple. Thanks!
25 Dec 2025 13:05 #340496 by tommylight
Most probably they will not work, inductive proximity sensors react to metal by inducing a magnetic field, but do give it a try, they might react, and might be polarity sensitive....
