XHC-WHB04B-06 rotary knob button feed rate not work
25 Jan 2026 16:09 #341899 by andrax
I have a question about the configuration of the XHC WHB04B-06.
I already asked this question in the German forum but unfortunately did not receive an answer.
First of all, the handwheel works perfectly except for the rotary knob button.
Here I can only set the increments. But I also want to control the feed rates.
I think the settings need to be adjusted here:
# GUI feed rate related signals can be used when program is running moving GUI slider
net pdnt.feed-override.scale whb.halui.feed-override.scale halui.feed-override.scale # needed for both FeedOverride+/- and rotary knob button
net pdnt.max-velocity.value whb.halui.max-velocity.value halui.max-velocity.value # needed for Mpg mode : button feed position% * max-velocity = Mpg feedrate
# take feed override min/max values from/to the GUI
net pdnt.feed-override.value halui.feed-override.value whb.halui.feed-override.value # GUI feed rate related signals
net pdnt.feed-override.increase whb.halui.feed-override.increase halui.feed-override.increase
net pdnt.feed-override.decrease whb.halui.feed-override.decrease halui.feed-override.decrease
I just don't know which ones?
25 Jan 2026 16:49 #341905 by andypugh
Which GUI are you using?
25 Jan 2026 16:52 #341906 by andrax
I use gmoccapy.
So far, I have found that these two signals control the feed rate:
gmocacapy.spc-feed.value
gmocacapy.spc-speed.value
25 Jan 2026 17:03 #341909 by andypugh
You could quickly check if those have the desired affect by opening halshow, opening the "watch" tab and picking those pins from the tree. Then you can set values directly.
If that works then link them up in HAL.
Time to create page: 0.139 seconds
