I start with a pyvcp panel...
Drive fwd 1 station button calls in section in my comp
Set tool 1 button calls m61q1
Then i add buttons tool1 tool2.... tool6 to call m6 t1....t6
If i hit drive fwd 1 station it rotates exact 1 station fwd. goes then backward and reduce pwm to get it locked against the pawl.
Now i check temperature ever 15 minutes of driver and dc motor.
Next step is calculating the distance from actual tool position to taeget tool position.. like from tool 1 to tool 6... or from tool 6 to tool 3... handling the rollover would be interesting... we will see in the next days.
If this done is the last step the movement... with the calculated distance on position to go forward i can multiplie with the forwardtime from position to position.. the locking part is not so sensitive.
So we will see... toolchanger without feedback... very oldschool... complete openloop.
