Help with Gantry Setup - X Y Z X
06 Dec 2010 03:51 #5874
by BWay
Help with Gantry Setup - X Y Z X was created by BWay
I have a CNC router I am setting up using Gecko 320's with a X Y Z X configuration. I have gone over the INI and HAL files a million times and can't get X1 and X2 to move together. Ironically I had this working a few days ago but something changed and it isn't working now. Here are my INI and HAL files...
#Custom BDW24368.hal file created 11/24/10
loadrt probe_parport
loadrt hal_parport cfg="0x378 out "
setp parport.0.reset-time 3500
loadrt stepgen step_type=0,0,0,0
addf stepgen.update-freq servo-thread
net spindle-cmd <= motion.spindle-speed-out
# Invert pins to make motors move in right direction
setp parport.0.pin-02-out-invert 1
setp parport.0.pin-03-out-invert 1
# Hook up the step and dir signals to the parport pins
# Axis X and X2 are the same axis but different motors
net xstep => parport.0.pin-02-out
net ystep => parport.0.pin-04-out
net zstep => parport.0.pin-06-out
net astep => parport.0.pin-08-out
net xdir => parport.0.pin-03-out
net ydir => parport.0.pin-05-out
net zdir => parport.0.pin-07-out
net adir => parport.0.pin-09-out
setp parport.0.pin-02-out-reset 1
setp parport.0.pin-04-out-reset 1
setp parport.0.pin-06-out-reset 1
setp parport.0.pin-08-out-reset 1
# Hook up estop pins
net estop-ext <= parport.0.pin-10-in-not
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 15200
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 15200
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 15200
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
setp stepgen.3.position-scale [AXIS_3]SCALE
setp stepgen.3.steplen 1
setp stepgen.3.stepspace 0
setp stepgen.3.dirhold 15200
setp stepgen.3.dirsetup 35000
setp stepgen.3.maxaccel [AXIS_3]STEPGEN_MAXACCEL
net apos-cmd axis.3.motor-pos-cmd => stepgen.3.position-cmd
net apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb
net astep <= stepgen.3.step
net adir <= stepgen.3.dir
net aenable axis.3.amp-enable-out => stepgen.3.enable
net estop-ext => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
Here is the Kinematics.hal file
############################## Kinematics & Motion Controller ####################################
# Kinematics
loadrt gantrykins
# Settings for gantrykins
setp gantrykins.joint-0 0
setp gantrykins.joint-1 1
setp gantrykins.joint-2 2
setp gantrykins.joint-3 0
# motion controller, get name and thread periods from ini file
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD
Here is my INI File
[EMC]
MACHINE = BDW24368
NML_FILE = emc.nml
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
INTRO_TIME = 5
PROGRAM_PREFIX = /home/brad/emc2/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = emc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 30382
SERVO_PERIOD = 1000000
[HAL]
HALUI = halui
HALFILE = kinematics.hal
HALFILE = BDW24368.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
# add halui MDI commands here (max 64)
[TRAJ]
AXES = 4
COORDINATES = X Y Z
MAX_ANGULAR_VELOCITY = 10.00
DEFAULT_ANGULAR_VELOCITY = 1.00
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 1.00
MAX_LINEAR_VELOCITY = 10.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_0]
NAME = X1
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10.0
MAX_ACCELERATION = 100.0
STEPGEN_MAXACCEL = 125.0
SCALE = 2178.24
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -36.0
MAX_LIMIT = 36.0
HOME_OFFSET = 0.0
[AXIS_1]
NAME = Y
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10
SCALE = 3291.36
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -24.0
MAX_LIMIT = 24.0
HOME_OFFSET = 0.0
[AXIS_2]
NAME = Z
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10.0
SCALE = 1611.12
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
[AXIS_3]
NAME = X1
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10.0
SCALE = 2178.24
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -36.0
MAX_LIMIT = 36.0
HOME_OFFSET = 0.0
I have switched the X1 and X2 motors and it is not a hardware issue. My breakout board shows that both step and directions are working on both x1 and x2 pins but I have a feeling that somehow the encoder for X2 isn't working in when X1 is working. Just a hunch...
Thoughts...I really need some help with this!
# Kinematics
loadrt gantrykins
Here is my INI File
[EMC]
MACHINE = BDW24368
NML_FILE = emc.nml
DEBUG = 0
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
INTRO_TIME = 5
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 30382
[HAL]
HALUI = halui
[HALUI]
[TRAJ]
AXES = 4
COORDINATES = X Y Z
LINEAR_UNITS = inch
CYCLE_TIME = 0.010
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
[AXIS_0]
NAME = X1
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10.0
SCALE = 2178.24
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -36.0
MAX_LIMIT = 36.0
HOME_OFFSET = 0.0
[AXIS_1]
NAME = Y
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10
SCALE = 3291.36
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -24.0
MAX_LIMIT = 24.0
HOME_OFFSET = 0.0
[AXIS_2]
NAME = Z
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10.0
SCALE = 1611.12
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -8.0
MAX_LIMIT = 8.0
HOME_OFFSET = 0.0
[AXIS_3]
NAME = X1
TYPE = LINEAR
HOME = 0.0
MAX_VELOCITY = 10.0
SCALE = 2178.24
FERROR = 0.05
MIN_FERROR = 0.01
MIN_LIMIT = -36.0
MAX_LIMIT = 36.0
HOME_OFFSET = 0.0
06 Dec 2010 11:20 #5877
by Rick G
Replied by Rick G on topic Re:Help with Gantry Setup - X Y Z X
Not sure what you are describing "can't get x1 and x2 to move together" are they out of sync or only one moves?
It seems that if you are getting step and direction at the breakout board it could be a hardware problem.
Can you jog the axis? Check to make sure step and direction pins are not reversed?
Rick G
Rick G
06 Dec 2010 11:37 - 06 Dec 2010 11:38 #5878
by BWay
Replied by BWay on topic Re:Help with Gantry Setup - X Y Z X
I can't jog X2 in joint or world mode. If I switch my pin output then I can jog X2 but not X1. If I unplug the X2 encoder the motor will run at top speed. If I assign Y to X2 and then I can jog both X1 and X2 (y) but obviously they are not slaved or synced. For some reason when I have X1 and X2 assigned then I just can get X2 to slave.
Thoughts?
Thoughts?
Last edit: 06 Dec 2010 11:38 by BWay.
07 Dec 2010 01:49 #5903
by BWay
Well it works. It seems most of my configuration was fine but I was having trouble with one of my servo's. I adjusted a few things and it seems to be working. Strange?!?
07 Dec 2010 12:10 #5905
by Rick G
Strange but good! Glad to hear it is now working.
Rick G
Rick G
07 Dec 2010 12:56 #5906
by BWay
I seems that one of my servo's was "weak" so while it was getting power it didn't have enough torque to run. This was making it look like I didn't have signal when really it was something else. I am still concerned there is something going on but after switching motors around and adjusting a few things it seems to be running ok. Any ideas on what this could be? I am fairly confident that it is something with the motor and not the encoder, cables, drives, or power supply since I have been able to switch and swap just about everything without problems with the expection of this one motor that acts up from time to time. Really strange.
09 Dec 2010 11:18 #5936
by Rick G
I think it pays to start with the simple things. Mechanical binding? I would double check all connections and cables to the bad motor.
On brush motors check the brushes, armature and springs. Check the resistance of the motor, windings etc.
Use a amp meter to see what kind of current is flowing on the good and the bad motors.
Rick G
Rick G
Time to create page: 0.738 seconds
