Xenomai RT kernel
  • endian
  • endian's Avatar Topic Author
  • Platinum Member
  • Platinum Member
05 Jun 2026 20:52 #346927 by endian
Xenomai RT kernel was created by endian
Hello,
is there any gentelman which has running Xenomai or Cobalt kernel for his iron?
I need some inspiration or talk what, how, prons and cons ... experiences !
thanks
23 Jun 2026 03:31 #347255 by tommylight
Replied by tommylight on topic Xenomai RT kernel
Probably been over 10 years since i last tried Xenomai, and on one PC it was better than RTAI, but on all others (4 or 5 PC's) it was worse regarding latency, and on 2 it did not boot.
Not good memories, but that is all i have.
The following user(s) said Thank You: rodw, endian
  • endian
  • Platinum Member
  • Platinum Member
26 Jul 2026 18:33 #348078 by endian
Replied by endian on topic Xenomai RT kernel
Thanks I did it with help of AI ... It was worse then Preemt-rt in default non custom stuff ... I left this idea when I saw how much custom thing I need to code alone to run something and it saves be 3us ...
great idea but much stuff around it
09 Sep 2026 12:45 #349491 by Hannes
Replied by Hannes on topic Xenomai RT kernel
Hi
Meanwhile, there is Xenomai3 and Xenomai4 support in master branch.
Details:
github.com/LinuxCNC/linuxcnc/issues/3878
Prebuilt Kernels and Linuxcnc 2.9.10 back-port for Xenomai4:
github.com/hdiethelm/xenomai3-linuxcnc
github.com/hdiethelm/xenomai4-linuxcnc
For me, it works well and I fully switched to Xenomai4.
The following user(s) said Thank You: endian, NWE
  • endian
  • Platinum Member
  • Platinum Member
05 Oct 2026 12:23 #350119 by endian
Thanks for the pointers, and for the prebuilt packages. They make it much easier for others to try this.
For context, here is where I ended up and why.
Hardware and goal
- Beckhoff C6930 industrial PC (i5-7500, 4 cores, no HT), Debian 12, no Beckhoff software.
- LinuxCNC with the IgH EtherCAT master, using an AX5203 drive over SoE.
- Strict 250 µs cycle, plus a custom 5-axis TCP (G43.4/G43.5) and a modified trajectory planner.
What I tried
1. Xenomai 3.3.3 Cobalt on Dovetail (CIP 6.1.170 kernel), built from source with Skylake tuning:
   - Core isolation, no P-states or C-states, tsc=nowatchdog, an i915 workaround and pci=noaer for the PLX backplane switch.
   - The native latency test showed about 3.6 µs max idle and 2.8 µs under load, with 0 overruns.
2. LinuxCNC on that kernel. At the time I was on 2.9 without a Cobalt flavour. Its HAL threads fell back to plain SCHED_FIFO in the Linux root domain, and latency-histogram showed about 36 µs, worse than PREEMPT_RT.
3. Xenomai 4 / EVL, with AI help, using default settings. In my hands it came out worse than PREEMPT_RT.
What I chose
Stock PREEMPT_RT (6.1.0-41-rt-amd64) with core isolation. On the isolated core at 250 µs, cyclictest gave 6–7 µs max, idle and under load. EtherCAT ran for a 30-minute soak with desktop load and stayed stable.
Xenomai's best case saved me about 3 µs, which is irrelevant against a 250 µs budget. To get even that, I would have had to write and maintain a lot of custom code myself: the glue between LinuxCNC, the EtherCAT master and the co-kernel, RTDM-capable NIC drivers, and the tuning for each. I decided that wasn't worth the maintenance, so I stayed on PREEMPT_RT.
What I'd like from this setup
- A hard 250 µs loop with low jitter that I can maintain on a stock Debian kernel.
- No dependence on a patched co-kernel for every kernel update.
- Eventually a self-contained appliance, with safety handled by external TwinSAFE/STO hardware.
Why I'm posting
- It's a great project, and I'm glad it works well for you.
- For anyone with a similar setup, the overhead around the co-kernel is real. On this hardware it buys microseconds, not a different class of determinism.
- If you have a minimal EtherCAT-master-on-EVL setup, or numbers for igb or e1000e with EtherCAT cycles, I'd like to compare. I'll also look at the Xenomai 3 / 4 support in master (issue #3878) with a fresh install.
Regards
The following user(s) said Thank You: NWE
Time to create page: 0.398 seconds
