Development: PID Tuning GUI and HAL
It is designed around my configuration which is the Mesa 5i20 with 7i40 motor drivers. Of course, with a little tinkering of the HAL components it can be used with anything.
Hope this helps some of you. I hope it isn't redundant either, although I couldn't find anything like it.
-Mikey
That is pretty slick.
You might want to consider adding FF1 and FF2, FF1 is especially important for plain H bridges and velocity mode servos.
Can't find module 'line4to2' in /usr/realtime-2.6.32-122-rtai/modules/emc2
rob
hi tried to use this today but seems you have a rt module in use that is not included
rob
ok no problem i see u need first post zip and then the updated bits on 2nd
rob
As for those extra components, you can do without them but I wanted to learn about making components, plus I prefer the compactness of them over wiring together a whole series of other components. What the project needs now is a graphical configurator...
![:D :D](/media/kunena/emoticons/laughing.png)
thanks in advance
Mauro
It is essentially an oscilloscope, so if you have used one of those, then you should be in good shape to get up to speed with halscope quickly.
My next goal is to find some more modern auto tuning algorithms and see about implementing those.
