Development: PID Tuning GUI and HAL
30 Jan 2011 12:59 #6871
by billykid
Replied by billykid on topic Re:Development: PID Tuning GUI and HAL
Thank you for your work and for quick response.
usually work with the analog oscilloscope and then how it was working.
for example if I open from emc2 halscope, moving motors emc2 halscope disappears ...
I read the guide to better halscope
thanks
Mauro
thanks
Mauro
31 Jan 2011 14:45 #6899
by dab77
Replied by dab77 on topic Re:Development: PID Tuning GUI and HAL
Ciao Mauro, when i use halscope i use to click in the left top angle of the window and select 'sempre in primo piano' i don't know the english way, but i'm sure you have that in italian..
this way the scope will be always in sight.
01 Feb 2011 19:47 - 01 Feb 2011 21:10 #6938
by billykid
grazie Dab77
I tried to run "halrun -f config.hal" but I get this error:
config.hal: 10: Can not find module 'line4to2'in / usr/realtime-2.6.32-122-rtai/modules/emc2.
I copied these forms, but should not be the same
mauro
mauro
Last edit: 01 Feb 2011 21:10 by billykid.
01 Feb 2011 21:23 #6940
by malleblas
Replied by malleblas on topic Re:Development: PID Tuning GUI and HAL
Hello Mauro,
The configuration is fine. There are some files though, with the extension .comp. These files are custom HAL components. To utilise these components you must pull up a terminal, traverse to the directory where the comp files are located and run:
comp --install *.comp
That should compile and install the HAL components, and next time you run the setup, those errors should go away.
For more information visit linuxcnc.org/docs/html/hal_comp.html
-Mikey
-Mikey
01 Feb 2011 21:30 #6941
by billykid
Thanks Mikey, I feel tomorrow I'm going to bed
02 Feb 2011 12:31 #6957
by billykid
I tried the first simple version, and now this error.
mauro@mauro-cnc:~/emc2/configs/tuning$ halrun -f config.hal
config.hal:4: Warning: File contains DOS-style line endings.
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/emc2/scope_rt.ko': -1 Unknown symbol in module
<commandline>:0: exit value: 1
<commandline>:0: insmod failed, returned -1
See the output of 'dmesg' for more information.
loadrt scope_rt failed
thanks
Mauro
thanks
Mauro
03 Feb 2011 21:35 #6982
by malleblas
Strange error, but outside the scope of the thread. Looks like a potential compilation problem? Otherwise, it might be an error emanating from your configuration file. Ensure that it has UN*X line endings, which I think are \n, not \r\n which is standard DOS/Windows.
-Mikey
-Mikey
04 Feb 2011 19:57 #6996
by billykid
in effect during the command: comp - install *. comp appeared warning ....
the test was done on a PC with the latest versions of EMC2 and hostmot2 on ubuntu 10.04
thanks
Mauro
thanks
Mauro
18 May 2011 15:31 #9914
by fabworx
Replied by fabworx on topic Re:Development: PID Tuning GUI and HAL
i downloaded the zip how do i start it? thanx
18 May 2011 16:17 #9915
by fabworx
im getting this error
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-2.6.32-122-rtai/modules/emc2/Module.symvers -C /usr/src/linux-headers-2.6.32-122-rtai SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-122-rtai'
CC [M] /tmp/tmp3V39IT/line4to2.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/tmp3V39IT/line4to2.mod.o
LD [M] /tmp/tmp3V39IT/line4to2.ko
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
cp line4to2.ko /usr/realtime-2.6.32-122-rtai/modules/emc2/
cp: cannot create regular file `/usr/realtime-2.6.32-122-rtai/modules/emc2/line4to2.ko': Permission denied
make: *** [install] Error 1
MODPOST 1 modules
