Wrong Direction
28 Mar 2011 21:22 #8228
by occesar_0
Wrong Direction was created by occesar_0
Hello
Well,I've been working with my cnc machine for a long time without problems but
suddenly one day the x axis stopped working. I found out that my "gecko drive"
was burned,so after replaced it, everything seemed to be ok and after test it
I found that there was no direction change in the servo. My parallel port is
configured in the same way as always but the direction state is always "1"
(In the jog mode after I pressed + or - the servo always go in the same direction)
I tried to invert the pins in the parallel port and nothing happens.
I don't know what else could it be,any suggestion?
Thanks in advanced
Thanks in advanced
28 Mar 2011 21:29 #8230
by BigJohnT
Replied by BigJohnT on topic Re:Wrong Direction
That pin might have got borked on the parallel port. Can you move the direction pin to another pin on your parallel port? There are many ways to find the solution by swapping out parts till you find the source of your problem.
Time to create page: 0.569 seconds
