Retrofit MAHO MH700c with Philips 432 control
10 years 3 months ago #77240 by micges
I removed old scales and installed new glass scales with 1um accuracy (5um should be enough for this machine).
I used those www.ateksensor.com/PDF_files/ENG/ALS4_Datasheet_ENG.pdf
They fit well into original places on machine.
10 years 3 months ago #77245 by akb1212
These scales looks like they are a good match to this machine yes.
I'm assuming you got the TTL output versions as they interface directly to the Mesa cards. But they have an option for 1Vpp output. With that you would be able to interpolate far better resolution. And that would be a good thing. I found my Maho MH600E behaves better and smoother when I use interpolators on my scales to increase resolution to 0,1um.
This was not to get better accuracy, but simply to get smoother movement.
The big question is where to get them, and what do they cost? If they are reasonably priced I'm assuming others here (me included) might be interested in getting some.
In the info they state there is an index pulse every 50 mm. That means you need to ensure it is within a certain position when starting a home search. Or else you might end up with a reference point that is a random multiple of 50 mm offset.
An alternative is to set up an extra sensor to tell it is within the correct range and can use the index pulse.
How are you solving this issue?
Anders
10 years 3 months ago #77248 by micges
I've used rs422 version and connect then directly to mesa 7i77.
I know that interpolated version could be better, maybe I'll do this next time.
As for homing I've used home switch that was mounted on machine,
10 years 3 months ago #77292 by andypugh
akb1212 wrote: In the info they state there is an index pulse every 50 mm. That means you need to ensure it is within a certain position when starting a home search. Or else you might end up with a reference point that is a random multiple of 50 mm offset.
Are the indexes all identical? I have heard of systems where the indexes are a variable number of counts apart, so after seeing two indexes you know where you are. Possibly also systems with indexes of different lengths.
10 years 3 months ago #77308 by akb1212
I got this info from the online datasheets and know nothing more about them. And I don't know what kind of quality they are either, but I would like to know as they seem to be a good fit to this kind of machines. And they come in analogue 1Vpp versions, which means they can be interpolated to very high resolution. That is if they are true high quality units with reliable and clean sine curves on the output that is.
You are right Andy, it would be a good idea to have some form of pattern in the index pulses to allow for absolute address (kind of). It would take some logic in the homing sequence, but I guess that's no problem in LinuxCNC. But the datasheets are quite clear it's with 50 mm intervals.
So you do need extra hardware on a Maho. I've been able to keep my original (analogue) scales with index pulses only at the end, and therefore don't need to add home switches or any other hardware to make the homing work. The only danger with that is if you are beyond the index point in the other end you end up with a totally offset coordinate system. But you will be able to reset it simply in LinuxCNC. With the original 432 controller it wasn't so easy, in particular on the Y-axis where it was impossible to move the screw by hand as it has a brake to keep the table from sliding down when shut off. You had to do all kinds of trickery to get it to move past that index pulse.....
But the question still stands, how much do they cost? And where can I buy them?
Anders
10 years 3 months ago #77311 by andypugh
akb1212 wrote: But the question still stands, how much do they cost? And where can I buy them?
Try eBay. EXE are 11uA interpolators and IVB are 1V interpolators.
Time to create page: 0.065 seconds
