Retrofit MAHO MH700c with Philips 432 control
11 years 4 months ago #59961 by uli12us
You can search for Müllernick or mullernick. He had converted a Maho7000 iirc withphilips 432 control, some years ago and
know everything about the strange philips linearencoders.
11 years 3 months ago #60854 by akb1212
Sorry to say you have the "bad" encoders on your Maho.
It's true that Nick Müller did something with these encoders, but I don't remember if he was successfull. I think he (and everybody else with this kind of scales) ended up replacing them with new scales. They are not possible to interpolate the same way the Heidenhain ones (the 11 uA/pp sin/cos ones) are either as the signals out of the read heads are already digital. And apparently they suffer from contamination as well since the scale is in the open.
I think you can find a lot of info about this in my thread over at Practical Machinist forum called "The fix your Maho thread". It's quite long by now, so I didn't have time to read through it all to find the relevant info. But from what I remember Nick gave some comments on his work on this in there somewhere.
And replacement parts are almost impossible to get. Or at least very pricy if you can find them. Your best bet would be to try to ask the others who have taken their Philips scalse out of their machines if they can sell you their old scales for parts. Again, there are a few in the above mentioned thread.
I also suggested one way to read them in that thread, but it involves sactrificing original Philips controller cards (that are somewhat valueable as spare parts). But you do need the correct version! And there is 2 read chains on each card so you need 2 cards for 3 (or 4) axes. Look in the thread for the details.
You do have good iron though (providing there is no extensive wear) in that machine, so it's a good candidate for retrofitting (better than mine!). But you do have your work cut out for you!
I'm planning on making a propper "how to retrofit a Maho with LinuxCNC" thread soon. I think I have all the info I need to get it done by now. I only need to find the time to get the machine done and make the documentation on how I did it. So it will be some time yet I'm afraid.
Anders
11 years 3 months ago #60871 by sascha
Well, these encoders are not so "bad" at all. I had a lot of fun to discover the old technology and adapt it to LinuxCNC (with help from Nick Müller about schamatics and signal analysis). It's long time ago (in 2011 if I remember right) and I have not created a lot of documentation, but I've uploaded the stuff to GitHub . So please have a look if you like.
Basically the scales consists of an photo diode array which analog output is multiplexed and PWM encoded. I have created a FPGA based decoder with pulse width measurement and sincos correlator in hardware and convert the sin/cos values to angle (within the 0,635 mm cycle) in software.
The machine is still in usage today and works fine. I have planned to create some detailed documentation in the wiki, but time is always a tight resource :-(
The following user(s) said Thank You: 6266
11 years 2 months ago #61178 by akb1212
Hehe, by "bad" I meant there are no support and spare parts to get, unlike the Heidenhain, where there are loads of available spare parts for cheap. From a technical point of view I'm sure the Philips scales are just as good as the Heidenhain ones. Possibly except from the fact that they are using an open design which is prone to contamination.
I wasn't aware someone had done a serious job of making these work, and I'm impressed you did go through the effort of doing that. If you have a working unit and would be willing to share it I urge you to share what you already have on the PM forum. I know there are several others out there who will come across this problem in the future too.
Maybe you can even make a readily available product for sale and be able to get a little return for your time spent. But you shouldn't expect to get rich though ;)
What interpolation factor are you able to get out of these BTW. It would be interesting to know how accurate they are compared to the Heidenhain scales.
Out of curiosity, do you think it would be possible to use any of the iC-Haus read heads or something to read these scales? They do much the same as you seem to be doing.
Anders
  • aventtini
  • New Member
  • New Member
11 years 3 weeks ago #63674 by aventtini
Replied by aventtini on topic Retrofit MAHO MH700c with Philips 432 control
I have also a mh500 that want to retrofit . I need some info on this philips scales . I was thinking to change them but they have a spacial place on the machine body and there is not room for a new one.
11 years 2 weeks ago #63696 by uli12us
Heidenhain have similiar open scales, I fear because the scales are highly precise parts, they are not really cheap.
In the case of Mesa Boards the best way, were the scales with TTL-Output.
www.heidenhain.de/de_EN/products-and-app...tion-guide-for-lida/
Time to create page: 0.168 seconds
