- drimaropoylos
- Thank you received: 39
11 Jun 2019 21:47 - 11 Jun 2019 21:49 #136664
by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Last edit: 11 Jun 2019 21:49 by drimaropoylos.
- drimaropoylos
11 Jun 2019 21:51 #136666
by drimaropoylos
- Thank you received: 4586
12 Jun 2019 15:24 #136748
That is very similar to the variable speed drive in my lathe. I don't think it is actually variable, but the parts are very similar:
bodgesoc.blogspot.com/search/label/holbr...Drivetrain%20Autopsy
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
Another speeder with friction design.
The springs force the balls to make contact with the races
- drimaropoylos
12 Jun 2019 17:06 #136763
by drimaropoylos
Clever design
- R2AIV
22 Jul 2019 13:47 #140173
by R2AIV
Replied by R2AIV on topic Retrofitting a 1986 Maho MH400E
Hi! I have one question about AXIS user interface. How i can hide error messages in right down corner of the window? I want AXIS to showing it in console window only, not in main GUI window.
- RotarySMP
- Thank you received: 563
24 Jul 2019 06:12 #140397
by RotarySMP
No Idea. I use Gmoccapy. Probably best to ask that question in the AXIS subforum.
- ninorazpotnik_1
01 Aug 2019 07:57 - 01 Aug 2019 11:36 #141077
by ninorazpotnik_1
Replied by ninorazpotnik_1 on topic Retrofitting a 1986 Maho MH400E
Hy. Im retrofitting a machine with indramat. Can you please send me a documentation of trk6?
e-mail deleted to protect from bots
Greetings Nino
Greetings Nino
Last edit: 01 Aug 2019 11:36 by tommylight. Reason: removed e-mail
- cgroth
- Thank you received: 9
01 Aug 2019 08:11 #141079
by cgroth
Replied by cgroth on topic Retrofitting a 1986 Maho MH400E
I just sent it.
- J Green
- Thank you received: 24
29 Aug 2019 02:54 #143525
by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Mark
Saw your You Tube video about making and using a thread milling tool . Looked very good - both the tool and your filming of it being used.
Hope you consider mentioning the thread milling tool here for other's to see.
What is the latest about the MAHO shifting software update ? Suppect most things are on hold untill Winter. Why is it that it can never be too hot for metal casting ?
Enjoy the summer while you can
Bob
Bob
- RotarySMP
30 Aug 2019 11:40 - 30 Aug 2019 11:48 #143650
by RotarySMP
Hi Bob,
I posted that thread milling video, but it was a while ago, back on page 88:
forum.linuxcnc.org/12-milling/33035-retr...00e?start=850#128761
Yep, my focus has been on other things over the summer. So far the Rev 2.0 of the gearbox hasn't happened. The next couple weeks I have to replace a balcony door and window, so no love for the machine shop.
The only thing I did lately was to use a friends taper removal wedges to drive off the MT#3 shank from the Tapmatic I bought, and order a 40 taper replacement. Oh, and I did whip up a moulding bench and finish off my sand muller. It works, but is so ugly it'll give you eyeball cancer, so I didn't upload and pictures or videos.
Mark
Mark
Last edit: 30 Aug 2019 11:48 by RotarySMP.
Moderators: piasdom
Time to create page: 0.655 seconds
