  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
16 Feb 2020 09:24 - 16 Feb 2020 09:47 #157511 by RotarySMP
Do you also use your CNC mill just as a manual mill, jogging around to remove metal? Every time I do this, I screw up. You can seen in this latest video, at 12:00, I figure it is a simple light cut in aluminium, so I'll jog around. Result ... big screw up!
The next step up the laziness ladder is just MDI'ing around. For me this results in a screw up about 3/4 of the time. I have sent a few end mills over the Jordan with doing that.
Moving further along the work flow path, if I sit down and write a program using conditional looping, the screw up rate seems to drop to about 25%, as we saw in my Lathe video three with the vee block, cutting at G0 instead of G01.
Tool paths generated from CAM have so far been most successful, but my natural abhorrence for work draws me to avoid CAD modelling parts and then creating a CAM path if it is only a simple part.
Mark
Last edit: 16 Feb 2020 09:47 by RotarySMP.
The following user(s) said Thank You: J Green
28 Feb 2020 18:17 #158772 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Hello to all, Mark I thing I have found solution to the neutral speed problem. You can either delete the “{ 0, 4 }, /* neutral 0 1 0 0 */” line in the lookup table on the mh400e_common.h file or ghange the { 0, 4 }, to { 1, 4 }, .
if the first solution wont work, in the second solution the gearbox will go to neutral only if you command 1 rpm.
28 Feb 2020 18:25 - 28 Feb 2020 18:26 #158773 by drimaropoylos
Or make it { 0, 0 }, /* neutral 0 0 0 0 */ so it will not care for the state of the gearbox and it wil not make changes to it
Last edit: 28 Feb 2020 18:26 by drimaropoylos.
28 Feb 2020 18:28 #158774 by drimaropoylos
static pair_t mh400e_gears[] =
{ /* rpm bitmask msb 11 10 9 8 7 6 5 4 3 2 1 0 lsb */
{ 80, 1097 }, /* 0 1 0 0 0 1 0 0 1 0 0 1 */
{ 100, 2377 }, /* 1 0 0 1 0 1 0 0 1 0 0 1 */
{ 125, 585 }, /* 1 0 1 0 0 1 0 0 1 0 0 1 */
{ 160, 1177 }, /* 0 1 0 0 1 0 0 1 1 0 0 1 */
{ 200, 2457 }, /* 1 0 0 1 1 0 0 1 1 0 0 1 */
{ 250, 665 }, /* 0 0 1 0 1 0 0 1 1 0 0 1 */
{ 315, 1065 }, /* 0 1 0 0 0 0 1 0 1 0 0 1 */
{ 400, 2345 }, /* 1 0 0 1 0 0 1 0 1 0 0 1 */
{ 500, 553 }, /* 0 0 1 0 0 0 1 0 1 0 0 1 */
{ 630, 1090 }, /* 0 1 0 0 0 1 0 0 0 0 1 0 */
{ 800, 2370 }, /* 1 0 0 1 0 1 0 0 0 0 1 0 */
{ 1000, 578 }, /* 0 0 1 0 0 1 0 0 0 0 1 0 */
{ 1250, 1170 }, /* 0 1 0 0 1 0 0 1 0 0 1 0 */
{ 1600, 2450 }, /* 1 0 0 1 1 0 0 1 0 0 1 0 */
{ 2000, 658 }, /* 0 0 1 0 1 0 0 1 0 0 1 0 */
{ 2500, 1058 }, /* 0 1 0 0 0 0 1 0 0 0 1 0 */
{ 3150, 2338 }, /* 1 0 0 1 0 0 1 0 0 0 1 0 */
{ 4000, 546 } /* 0 0 1 0 0 0 1 0 0 0 1 0 */
  • RotarySMP
  • Platinum Member
  • Platinum Member
07 Mar 2020 22:38 #159442 by RotarySMP
Thanks for looking into that. What we have been planning was to switch the control logic. Currently the gearbox.comp requests that LinuxCNC switches the spindle on and off, whereas we want to give the Gearbox.comp direct control of the spindle relays, and route LinuxCNC spindle requests to the comp. The neutral issue is something were were going to address at the same time. For these changes I am at the mercy of my nocturnal IT vampire though.
Mark
10 Mar 2020 12:44 #159646 by lukin1156
Replied by lukin1156 on topic Retrofitting a 1986 Maho MH400E
I also used the maho gearbox component and was dissatisfied with the M5 gear shift.
So just rewrite the line above and should it work without a problem?
Thank you for your work!
Greetings from the Czech republic!
12 Mar 2020 22:11 #159943 by drimaropoylos
I thing it will work, disconnect the (gearbox) motors and check while you make the first attempt so you wont crush the gearbox.
  • RotarySMP
  • Platinum Member
  • Platinum Member
14 Mar 2020 19:04 #160201 by RotarySMP
There is also a Simulator in github, so you should first run changes to the gearbox comp through that ti test them.
Mark
  • RotarySMP
  • Platinum Member
  • Platinum Member
16 Apr 2020 15:47 #164160 by RotarySMP
I wrote a short program (attached) to surface and trim the end of piece of stock, but made a typo in the fourth to last line.
o100 endwhile
instead of
o110 endwhile
When I tried to load the file, LinuxCNC tried to verify it, and got in an infinite loop. Is there are more elegant way to recover from this than hard rebooting the machine?
Mark
16 Apr 2020 17:41 #164169 by andypugh
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
Mark
"Esc" should work, but may take a while.
Moderators: piasdom
Time to create page: 0.198 seconds
