  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
16 Apr 2020 19:10 #164190 by RotarySMP
I just did it again. This time again a conditional loop:
C = -1
while [x GT Y]
x = [x-C]
So the thing looks until a number drops below another one, but it starts higher and increments by minus a negative number, therefore increasing to infinity. What an idiot!
I tried ESC, but after 3 minutes, still no response. I hate hard rebooting it all the time. Should learn to be more careful at coding.
Mark
16 Apr 2020 19:22 #164191 by Mike_Eitel
Replied by Mike_Eitel on topic Retrofitting a 1986 Maho MH400E
Silly idea: what happens when you trigger a linit switsch
16 Apr 2020 19:33 #164194 by tommylight
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
If that makes you feel better, it happened to me once a while back, can't recall exactly how and what, but it did. :)
I am pretty sure i was using 10.04 and Linuxcnc 2.5.
  • RotarySMP
  • Platinum Member
  • Platinum Member
16 Apr 2020 19:33 #164195 by RotarySMP
I got help from my linux guru.
In a terminal window:
top
...to get the number of the process stuck in the loop (Gmoccapy)
kill -9 xxxx (process number)
Linuxcnc errors out with the GUI killed, and you can restart LinuxCNC without a reboot.
  • RotarySMP
  • Platinum Member
  • Platinum Member
10 May 2020 11:21 - 10 May 2020 13:07 #167252 by RotarySMP
This is OT, but this week I took time out from my mini-lathe project to make a John Lennon statue for my wife
Mark
Last edit: 10 May 2020 13:07 by RotarySMP.
The following user(s) said Thank You: tommylight, johnmc1, J Green
12 May 2020 14:05 - 12 May 2020 14:47 #167526 by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
Hi everyone,
I've been very busy the last couple of months due to Corona.
Here are my latest protective measures ;-):
The cover was half the price last year:
www.aliexpress.com/item/32386329085.html...1.0.0.52034c4duhsWhv
A picture of the full assembly will follow tomorrow, as the paint is still wet.
Cheers
Hanno
Last edit: 12 May 2020 14:47 by hanmon.
The following user(s) said Thank You: J Green
13 May 2020 09:52 #167638 by hanmon
done:
13 May 2020 15:59 #167658 by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Looks as if you guys have been productively busy. Hanno - thanks for including the extra details, the bellows cover looks great. What is the latest on the rotary axis?
Mark - Due consider ,how nice it is to sleep at night without wondering if those strange sounds in the dark are payback actions the lady who puts light in your life hath taken a dim view of !
Not much progress here , cold temperature and now the virus thing.
Stay well
Bob
  • RotarySMP
  • Platinum Member
  • Platinum Member
18 May 2020 11:42 - 18 May 2020 12:00 #168142 by RotarySMP
Are those Z axis bellows covers MAHO parts, or did you get the chinese to make them for you? My Maho could also do with a fig leaf to modestly cover her exposed parts :)
By the way, I screwed up and crashed the MAHO's slotting head (it is in my last lathe video...)
Doesn't appear to have caused any permanent damage to the MAHO or slotting head. Just the boring bar bent.
Mark
Last edit: 18 May 2020 12:00 by RotarySMP.
20 May 2020 15:44 #168387 by hanmon
Axis:
I had to swap the servo to the front-side, as the bellows cover was a little too big unfortunately :-(
Now the servo is a little bit in the way, when adjusting the chuck.
I mechanically adjusted the Gear/Chuck etc. to be perfectly parallel to the table yesterday and installed everything.
Next step is to wire everything up and finally paint it green.
Moderators: piasdom
Time to create page: 0.431 seconds
