  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
23 May 2018 17:12 #111069 by RotarySMP
Nice design John. Reusing the existing housing is going to save you a bunch of time.
I screwed up the design of my lower button mount plate. With the switches mounted vertically, there is not enough space above for the monitor, and below for the housing flange, so I will have to remake that plate and rotate the switches.
Mark
24 May 2018 15:25 #111086 by andypugh
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
if those are modular switches you might be able to just move the contact blocks further back. (I don't know if I have seen spacer blocks)
28 May 2018 06:19 #111213 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
Thanks John, at present, there is currently nothing implemented to call the gearchange.clp is there?
Mark
Hi to all, Mark the ladder takes the spindle-vel-cmd-rpm value from hal and sets the closest combination of gears to match that value. During the gear change ladder sets the spindle-at-speed to 0 so no axis move can take place.
The configuration is not compete but it will change the gears wen an S command is placed and during the change it will hold the axis from moving. Ladder must also control net spindle-enable, net spindle-cw, net spindle-ccw and spindle-vel-cmd-rpm must be changed to spindle-vel-cmd-rpm-abs (always positive value).
28 May 2018 06:30 #111215 by drimaropoylos
In custom.hal
net spindle-vel-cmd-rpm classicladder.0.floatin-01
net spindle-at-speed classicladder.0.out-08
28 May 2018 06:33 #111216 by drimaropoylos
Must change to something like
net spindle-enable classicladder.0.in-08
net spindle-cw classicladder.0.in-09
net spindle-ccw classicladder.0.in-10
net spindle-vel-cmd-rpm-abs classicladder.0.floatin-01
net plcoutput_1k8 classicladder.0.out-08 => hm2_5i25.0.7i77.0.0.output-08
net plcoutput_1k9 classicladder.0.out-09 => hm2_5i25.0.7i77.0.0.output-09
net plcoutput_1k10 classicladder.0.out-10 => hm2_5i25.0.7i77.0.0.output-10
net spindle-at-speed classicladder.0.out-11
  • RotarySMP
  • Platinum Member
  • Platinum Member
01 Jun 2018 11:58 - 01 Jun 2018 13:10 #111386 by RotarySMP
Hi John,
Sorry for the slow response. Been rather busy with other stuff lately. Cool that you got the ladder control of the spindle speed working. I would love to see a video of that.
Hi Andy,
I'd need at least inch long standoffs for the switches, and then I couldnt mount the front panel with the switches installed and cabled. Trying to wire them up inside the house would be a nightmare. Easier just to remake the steel mount strip with the switches rotated. I finished it yesterday, and threw some primer on it. I'll paint it green this evening.
Probably should have stuck with the huge MAHO control box like John is doing, but space in my basement is at a premium.
Mark
Last edit: 01 Jun 2018 13:10 by RotarySMP.
03 Jun 2018 15:10 - 03 Jun 2018 15:17 #111512 by drimaropoylos
We have a little problem with the e-stop double bouton. Gmoccapy activates only after we release the bouton, so the 24 volt from the Mesa to 209 joint to activate the 19K1 is not going to be present when we press the 3SH1 bouton (the second bouton contact).
Last edit: 03 Jun 2018 15:17 by drimaropoylos.
04 Jun 2018 05:08 #111574 by drimaropoylos
One solution it will be not to drive directly gmoccapy.v-button.button-0 pin from the mesa bouton input, but instead pass the signal from a timer that pulse for a fix time.
04 Jun 2018 08:31 - 04 Jun 2018 08:33 #111578 by drimaropoylos
Never mind, I was wrong, the boutons pin of gmoccapy have different behavior than soft boutons on screen. They activate gmoccapy as soon you press then and not after release them.
Last edit: 04 Jun 2018 08:33 by drimaropoylos.
  • RotarySMP
  • Platinum Member
  • Platinum Member
04 Jun 2018 11:17 #111589 by RotarySMP
Hi John,
Interesting observation. I hadn't notice that behavior. For testing I have the Physical start button from the the MAHO connected to close the EStop through one set of poles, and to signal V.button.0 through it's second poles. While pushing and holding that, I have been clicking the on screen V.button 1, and it has latched fine.
Mark
Moderators: piasdom
Time to create page: 0.246 seconds
