05 Jun 2018 10:59 #111665 by drimaropoylos
Replied by drimaropoylos on topic Retrofitting a 1986 Maho MH400E
I don’t think you make something wrong, I simply prefer that behavior of the machine
06 Jun 2018 06:23 - 06 Jun 2018 06:25 #111724 by drimaropoylos
You need the LinuxCNC Estop signal connected through your MESA card to the the MAHO 28X2-4 pin on the I/O board so that the Mill will E-Stop automatically if LinuxCNC senses an internal software screw up.
I will use the MAHO 28X2-4 pin from relay board to feed motion.enable pin on linuxcnc so the controller knows if something went wrong.
Last edit: 06 Jun 2018 06:25 by drimaropoylos.
06 Jun 2018 06:46 #111725 by drimaropoylos
In you approach is that when everything is power off gmocapy will show emergency off even if all the emergency boutons are on, when you press estop everything is power up except the servos, in this state gmoccapy will show emergency bouton on and power bouton off, and then when you press the power bouton servos goes on and gmoccapy show power on.
In my approach I have described what happens in previous post.
Is there a standard (or mainstream approach) to describe what is the proper behavior of a machine to the estop and power boutons.
06 Jun 2018 14:33 #111758 by drimaropoylos
06 Jun 2018 14:54 - 06 Jun 2018 14:56 #111760 by drimaropoylos
Also we have to separate the 24volt field power(24V from 200 pin) from 24volt logic power (24V from 204 pin) in 7i77 (tb1 to the right), or gmoccapy won't start with only 24volt from 200 pin
Last edit: 06 Jun 2018 14:56 by drimaropoylos.
06 Jun 2018 16:13 #111767 by drimaropoylos
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Jun 2018 14:13 - 07 Jun 2018 14:24 #111881 by RotarySMP
Yeah I picked up on that as well. I see from my notes...
24VDC: the field power is also available on MAHO terminal strip 28X3. There are three 24VDC buses, but two are powered through the E-Stop relays. You need the mesa cards powered at start up to enable LinuxCNC to connect to all pins. Therefore, you need to connect to as follows
7i77 28X3
TB2-1 -- 204 – 24VDC
TB2-8 - 201 – GND
Last edit: 07 Jun 2018 14:24 by RotarySMP.
The following user(s) said Thank You: drimaropoylos
11 Jul 2018 02:29 #113995 by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
Shirley - the new paint is now dry!
Come on guys , what is the latest .
Really need some more Maho progress reports.
Make it up if you have to. I am starting to get withdraw shakes, it's been so/too long..
Don't want to hear about the shop now being too hot.
I know LIFE tends to get in the way -- at least a photo of the garden with the Maho in the background. What the heck it's summer -- you-all can work all night without fingers freezing to the cold metal.
Probably out on Maho beach with a dead cell phone and don't even know what day it is !
  • RotarySMP
  • Platinum Member
  • Platinum Member
11 Jul 2018 06:47 #113999 by RotarySMP
You can just feel it can't you. I get a free weekend, waste invest time in making lifting tongs, and a pouring shank for my new crucible, and also make some progress on my sand muller,
www.alloyavenue.com/vb/showthread.php?13...iewfull=1#post210979
...then yesterday I cranked up the 3D printer and started printing the pattern for the lathe faceplate...
....and BAMM!!! JG is calling me out for my wayward priorities :)
Now I feel guilty. Cause I knew I needed to use the 3D printer to print out some new MAHO buttons since I rotated the switches, and can then continue with the user panel wiring.
Mark
  • RotarySMP
  • Platinum Member
  • Platinum Member
18 Jul 2018 06:27 - 18 Jul 2018 06:29 #114447 by RotarySMP
No much progress, but yesterday I finished printing the lower row of buttons, and started installing them.
These ones have the clearest writing I've yet printed.
Mark
Last edit: 18 Jul 2018 06:29 by RotarySMP.
Moderators: piasdom
Time to create page: 0.382 seconds
