- R2AIV
15 Feb 2019 17:33 #126573
by R2AIV
Replied by R2AIV on topic Retrofitting a 1986 Maho MH400E
Thank you! This is identical to what I have.
- J Green
- Thank you received: 24
15 Feb 2019 23:51 #126592
by J Green
Replied by J Green on topic Retrofitting a 1986 Maho MH400E
R2AIV
Thanks for the photos . Other than newer computer a "T" series does seem the same as other MH400 xx machines. A machine I got also had a broken white plastic shifting gear.
Are you going to re-use the old keyboard ? If so it would get you some bragging rights !
For those that have a rotary axis here is a link to the ROD 271
product.heidenhain.de/JPBC/image/HWP.EN/...53-93_rod_271(c).pdf
Keep warm
Bob
Keep warm
Bob
- hanmon
- Thank you received: 23
18 Feb 2019 09:02 #126711
by hanmon
Replied by hanmon on topic Retrofitting a 1986 Maho MH400E
Hi Bob,
the link does not work.
@R2AIV: "Thank you! This is identical to what I have. " what do you mean ?
- Mccartymachine1
19 Feb 2019 01:26 #126743
by Mccartymachine1
Replied by Mccartymachine1 on topic Retrofitting a 1986 Maho MH400E
- hanmon
19 Feb 2019 08:17 #126754
by hanmon
- aradralami
19 Feb 2019 08:38 #126756
by aradralami
About the second video nice spindle! What misting system is he using?
Replied by aradralami on topic Retrofitting a 1986 Maho MH400E
Found the videos , my thinking is compare the brief scans of the lathe control panel to the Deckel control panel . Of note to me was the lathe control panel using also a non stainless material.
There is also some ".A" axis lust and a very brief bit on his coolant system. Wish Mr Roger M would video more on those machines --- Hint Hint Wish Wish
Keyboard Control
Coolant
Mark looking at the remains of the slotter cutting bit -- I am wondering if that was just a excuse to justify having a tool & cutter grinder ?
Bob
- R2AIV
19 Feb 2019 14:19 #126771
by R2AIV
I mean your previous link =)
- Thank you received: 4586
26 Feb 2019 21:08 #127190
As far as I know his mister system is entirely home-made, down to the firmware that runs it and the display panel.
I have a picture that shows his control console from a different angle.
It's a pity the f1-2000.co.uk went down, some of his scale model stuff is astonishing.
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
- aluplastvz
- Thank you received: 9
27 Feb 2019 21:00 #127293
by aluplastvz
Replied by aluplastvz on topic Retrofitting a 1986 Maho MH400E
Hi all for this forum
I bought this machine for starting with Linukcnc and Mesa cards, I hope that I will succeed because I have seen many good comments here.
- RotarySMP
- Thank you received: 563
01 Mar 2019 08:06 #127390
by RotarySMP
Hi, That looks like a real beast. Please post some pictures of the layout inside the control cabinet. What control does it currently have? Which linear encoders are fitted? Does it have a tool changer, pallet changer etc?
Does the current control work? Do you have the wiring schematics for it. You really need them to do a retrofit.
Mark
Mark
Moderators: piasdom
Time to create page: 0.201 seconds
