12 Mar 2019 15:40 - 12 Mar 2019 15:41 #128446 by pl7i92
Replied by pl7i92 on topic Retrofitting a 1986 Maho MH400E
i got here in a Shop at a Education center 5 of this Machines
but with a Center Motor Clutch
so only one axis is Able to move at once
and also in G18 Mode
Haidenhain TNC124 controlled
the earliest mashines that where manufacterd for HARD Old Men Use no REF
Full Handuse
All axis got Handwheels
But they got the Original E-Plans and all the Drawings with them
From 1981 Build
Last edit: 12 Mar 2019 15:41 by pl7i92. Reason: time
  • RotarySMP
  • RotarySMP's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 Mar 2019 08:02 #128491 by RotarySMP
Those would be MAHO 400P models. Different beast to a MH400E. It would be a much bigger job to do a LinuxCNC conversion on one, as you need to get rid of that single axis motor and gearbox system, and drive the axis screws (are they even ballscrews?) from three separate servos.
So are you planning to retrofit them? Woul probably be cheaper to sell all five and buy a more modern machine.
Mark
13 Mar 2019 08:33 #128495 by Glemigobles
Replied by Glemigobles on topic Retrofitting a 1986 Maho MH400E
Super-quick service from eusurplus.com and DHL Express, I got all my parts this morning and they were just shipped yesterday (from Portugal to Poland)!
I'm a little envious since I also ship a lot of my products in Europe but my parcels are much larger and the prices are higher for slower delivery. Such is life.
Here's a picture of everything I got, now I need to find some free time and actually read what these parts are and how to connect them to each other (and to the PC and the Maho). I was going by Mark's updated list of "what I would've done had I known better", but unlike him I still have absolutely no idea what I have here :)
My initial plans for the retrofit have gone awry somewhat. Usually in my small business there were week-long spells of absolutely nothing happening, leaving me free to plot and scheme, but since at least last month I'm constantly trailing behind trying to fulfil outstanding orders. Since the Maho is central to actually manufacturing my products, I might just have to post a "sorry, we're taking a break this week" and use that time for the retrofit. I'll find a way.
13 Mar 2019 09:14 #128497 by Glemigobles
I already see I got the wrong break out board with the 7i74 instead of the 7i44 :)
  • RotarySMP
  • Platinum Member
  • Platinum Member
13 Mar 2019 14:56 #128522 by RotarySMP
I didn't notice the difference between the 7i44 and the 7i74 until now either. At least this is one of their cheapest cards. Maybe they will let you exchange it.
Mark
13 Mar 2019 15:25 #128525 by tommylight
Replied by tommylight on topic Retrofitting a 1986 Maho MH400E
That is a 7i74 in the picture and that is the one you need with 5i25. 7i44 is for a 50 pin header.
You are all good to go. You need 2 parallel port cables and 2 RJ45 patch cables, straight, not crossover, a power supply depending on the signalling voltage you will need, usually 24V.
13 Mar 2019 15:27 #128526 by andypugh
Replied by andypugh on topic Retrofitting a 1986 Maho MH400E
I _think_ that the Smart Serial cards will work with either straight or crossover cables.
  • RotarySMP
  • Platinum Member
  • Platinum Member
13 Mar 2019 15:40 - 13 Mar 2019 15:40 #128529 by RotarySMP
Doesn't he need that DB25 connection on the 5i25 for the 7i77? The 5i25 has a second DIL26 pinhead, for connecting a 7i44.
Or will the 7i77 work if it you connect
7i77 through TB6-> 7i74 , then 7i74 --> 5i25 through the DB25 cable?
Mark
Last edit: 13 Mar 2019 15:40 by RotarySMP.
13 Mar 2019 15:40 #128530 by PCW
Replied by PCW on topic Retrofitting a 1986 Maho MH400E
Alas, SSerial cards cannot have their RX/TX pairs swapped.
The interfaces are designed for straight through cables.
You might be confused Ethernet, our Ethernet cards will work with straight
through or crossover cables (this is a common Ethernet feature known as MDIX)
13 Mar 2019 15:41 #128531 by PCW
You might be confused with Ethernet, our Ethernet cards will work with straight
Moderators: piasdom
Time to create page: 0.169 seconds
