MAZAK POWER CENTER V12 retrofit (if possible)
  • aventtini
  • aventtini's Avatar
  • Visitor
  • Visitor
04 Jul 2019 17:32 #138636 by aventtini
Replied by aventtini on topic MAZAK POWER CENTER V12 retrofit (if possible)
some updates , 2.5 axis , gear box on all axis, 2 gear on spindle , mechanical M19 , encoder on ballscrew ,0.14mm backslash on gears . I have finish the machine when I notice there is no encoder on spindle only a tacho . Put encoder the I see a a strange part that orient the spindle . I stuck at this piston because I don't know if it press on center of the piston or on the side .
05 Jul 2019 12:57 #138683 by andypugh
Replied by andypugh on topic MAZAK POWER CENTER V12 retrofit (if possible)
That's an interesting piston. I would guess that it operates a roller on a shaft coaxial with it, but without the other parts it's hard to tell.
  • aventtini
  • Visitor
  • Visitor
05 Jul 2019 13:36 #138688 by aventtini
Question is on shaft or sides
05 Jul 2019 13:41 #138689 by andypugh
Did you take it apart, or was it already disassembled?
That looks like something that would slide coaxially on the spidle shaft. But it would need a roller to operate on, and that would unbalance the spindle, so seems unlikely.
Moderators: piasdom
Time to create page: 0.159 seconds
