They can be connected together but you will loose all isolation from the noisy side of the machine.jeffie-3 wrote: O.K. GND is different than -5v or -12v
TB1 pin 1 and TB2 pin 8 run to the same terminal and that terminal runs to the negative side of the 5 volt supply.
PCW wrote:
tommylight wrote: NC switches should give 12V at the Mesa inputs when not tripped.
Check the wiring.
Yep and also, inputs must be 12V relative to field power GND = TB2 pin 8 when on
