Limit switchs
6 years 9 months ago #154069 by jeffie-3
Replied by jeffie-3 on topic Limit switchs
How do I disable the drive? When moving the table by hand using an indicator. I move 0.100 and get 0.375 on the dro. When I use command to move the table 0.100 the dro says 0.0834 and the indicator says 0.007 of movement.
6 years 9 months ago #154070 by PCW
Replied by PCW on topic Limit switchs
The drives should be disabled when in estop
(but the DRO should still work)
6 years 9 months ago #154071 by jeffie-3
OK I moved 0.100 on the indicator the dro says 0.4172. I am using a digital indicator.
6 years 9 months ago #154072 by PCW
Is this reliable?
( does moving another 0.1" add another 0.4172 to the DRO reading )
If so the scale is off by more than a factor of 4
This may be because you have not considered that a quadrature encoder
will have 4X its PPR counts per turn (a 2048 PPR encoder will have 8192 counts per turn)
The following user(s) said Thank You: jeffie-3
6 years 9 months ago #154073 by jeffie-3
Thank you. I looked at the manual it said one 360 turn was 2048 I never noticed the word quadrant. I just set it by the 2048. Thank you for the help. I multiplied the number in the INI file and it is close now. I'll tune the servos now. Again that you for the help.
6 years 8 months ago #157678 by jeffie-3
Replied by jeffie-3 on topic Limit switches errors
I am at the point I am getting ready to do the PID stuff. I needed to home the axis. When I home the machine and it hits the switch I get this
Z axis. Joint 2 following error.
Y Axis. Joint 1 following error.
X Axis. Joint 0 limit switch error.
How do I fix this?
Thank you.
Jeff
Time to create page: 0.097 seconds
