Limit switchs
6 years 9 months ago #154053 by jeffie-3
Replied by jeffie-3 on topic Limit switchs
The servo tuning instructions say to get the encoders scaled correctly in order to proceed with tuning the servos. How do I do that?
6 years 9 months ago #154056 by PCW
Replied by PCW on topic Limit switchs
You set the per axis ENCODER_SCALE parameters in the INI file to encoder counts per machine unit (machine units being inches or mm)
6 years 9 months ago #154061 by jeffie-3
When I ran the PnCConf I put in all of that. But when I move the table the numbers are wrong. I went back and double checked the encoder, the two gears and the ballscrew. Does the problem lie in tuning the servos? Or does the movement numbers have to correct before I tune the servos?
6 years 9 months ago #154062 by tommylight
6 years 9 months ago #154064 by jeffie-3
How do I correct it?
6 years 9 months ago #154067 by PCW
When moving the axes 0.100 it says on the screen 0.0834 What is a way to get that to match before I tune the servos?
Did you command a move of 0.100" and got an actual move of 0.0834" ?
this would be expected without tuning
Normally you would check the encoder scaling and direction with the drives disabled
by using an indicator
Time to create page: 0.177 seconds
