Retrofitting an 89 Chiron FZ12W aka Igor
6 years 2 months ago #179446 by anfänger
Finally done with rewriting my tool touch off scripts. I use the W offset to set the offset for large tools. So I can run them off center and in reverse.
6 years 1 month ago #182203 by anfänger
Added a new safety feature. I control the if one of the non uses tool changer arm goes down. If it does, the machine estops
It’s done my a python hal module.
The following user(s) said Thank You: Aciera, Mara2000
6 years 1 month ago #182459 by Mara2000
Hi Patrick,
could you please write me what needs to be changed in INI probe basic file for correctly displays and works in mm units instead of inches? Thanks a lot. Marek
6 years 1 month ago #182470 by tommylight
Ahoj Marek,
[TRAJ] AXES = 3 COORDINATES = X Y Z LINEAR_UNITS = mm <<<<<<<<<here should be mm ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_LINEAR_VELOCITY = 250.00 MAX_LINEAR_VELOCITY = 2500.00
The following user(s) said Thank You: Mara2000
6 years 1 month ago #182505 by anfänger
As tommylight said you need to set the linear_units in the INI to mm
Above I attached my whole config for my machine here a link again:
forum.linuxcnc.org/media/kunena/attachme...829/IgorProbe.tar.gz
You need to keep n mind if you want to have the display working in mm you need set set up the whole machine in metric units
6 years 1 month ago - 6 years 1 month ago #182547 by Mara2000
Thank you friends! I will try the settings in the workshop evening.
Last edit: 6 years 1 month ago by Mara2000.
Time to create page: 0.266 seconds
