Retrofitting an 89 Chiron FZ12W aka Igor
4 years 3 months ago #246519 by anfänger
I swapped connection between two servos. And it looks like it's the drive. Didn't get the 4th axis drive to work but this might be my lack of knowledge.
So trying to fix the drive or swap servo and drive for the Z Axis.
On my lathe I have good results with the lichuan 220 V servos.
The new spindle motor for the picomax is a lunyee using 400V.
I am thinking about swapping for the lunyee drive an servo, If I am happy with the spindle.
The only question is where the heck to place the new drive:
[img
Its quite crowded in there with the Simudive being such a big chunk. Only space would be by the brake resistor. Swapping all three servos would bring space gut is costly.
I need cheaper hobbies...
3 years 11 months ago #256684 by dinamik
Hello Anfänger I neeeeeed your help
I have the same machine as you Chiron Fz16 and the only difference is that mine does not have a fourth axis, but the X axis is 4 meters
on which there is a linear encoder with a signal converter + 2 spindles.
I removed one so there remains one spindle with 6 atc-s its practically implies the same scenario as on your machine.
1. I need exact models mesa cards,terminals,cables---links to buy
2. If you have some I/O schematic for connecting ATC, SPINDLE, ANALOG SIMO DRIVERS+ENCODERS, LIMIT SWITCHES... to MESA
4. Configuration files for linuxcnc/hall and ATC Screen files
Thanks in advance
3 years 11 months ago #256685 by anfänger
HI,
I used:
1. Mesa 7I92H Anything I/O Ethernet card.
2. Mesa 7I77 Analog servo interface plus I/O daughtercard
3. Mesa 7I74 Eight Channel RS-422/485 interface/ RJ45 Breakout.
4. Mesa 7I71 Isolated remote power driver card.
5. Mesa 7I70 Isolated remote digital input card.
You can combine 1 and 2 today with a 9i97 today.
The rest are some SubD and Other breakout boards.
BUT you have another machine, mine was a Sinumerik / Simudrive machine. You have Heidenhain Control, so I guess you also have different drivers. This is why my schematics won't help you.
I have most covered here in the thread. But I also have some more details in ma blog:
barn.works/2019/linuxcnc-retrofit-von-igor-teil-1/
But some things are outdated and I wouldn't do it the same way again.
Actually I will rewire Limit switches, E-stop and so on. Cause I am forced to start swapping the servo drives.
3 years 11 months ago #256687 by dinamik
No!!
Complete equipment is Siemens:
dc motor, driver, reg. and dead control---sinumeric system 3
only the linear scale is Hidenhain.
3 years 11 months ago #256689 by dinamik
Siemens system 3
3 years 11 months ago - 3 years 11 months ago #256690 by anfänger
Ok, mistake from my side, I can share my data if yo give a mail address.
BUT I mine has a sinumerik 810 with simudrive 610 three phase 400V Servo and spindle.
But I would do a lot more rewiring today than in the past.
And not everything was wired as in the schematics. Took me quite a while to figure it out. And of course documented it baldy :D
Last edit: 3 years 11 months ago by anfänger.
Time to create page: 0.529 seconds
