Retrofitting an 89 Chiron FZ12W aka Igor
3 years 10 months ago #258802 by anfänger
the 7i97 with the other cards should have enough IO's of your machine.
I would start by making me a List of all the IO's on the machine which are in use what addition IO's I will add later and then chose the suiting card combination. I have plenty in spare on the Chiron. With the latest cards I my have opted for another setup.
3 years 10 months ago #258803 by dinamik
3 years 10 months ago #258885 by dinamik
My I/O scenario.....
3 years 10 months ago #258887 by anfänger
Hi Is your Spinde really Really run by IO's Mine runs with +-10V
and have just one controller release.
have you checked with the wiring?
Watt about the controller releases for x y and z? are there none?
Same for Estop out?
Mine works with bi stable air valves. So I have one relay for spindle up and another for down.
and a relay for all tools up. You should check that.
But still then you should be fine with one 7i97 and one 7I84
3 years 10 months ago #258889 by dinamik
You are right, I just saw in the documentation that it is the same as your spindle at +/- 10V also for the spindle up and down via two relays as yours.
As for releasing the axes, I can't figure it out...but as far as I remember when it was working properly I had to release the e-stop after starting the machine in order to start the control and axes.
Today I am ordering 7i97 and 7I84, so we will be in touch when they arrive.
Best regards
1 year 10 months ago #317325 by Derek
Which spindle oil is used? Is the chamber where the motor and spindle connect also the oil reservoir? I too have a chiron fz12w I retrofitted.
Time to create page: 0.259 seconds
