Spindle speed sensor for a Bridgeport 2J head
6 years 3 weeks ago #185017 by OT-CNC
Here is the link to the backgear mod from Pico:
pico-systems.com/bridge_spindle.html
6 years 3 weeks ago #185063 by rogerfries
Replied by rogerfries on topic Spindle speed sensor for a Bridgeport 2J head
I sure like the Pico solution, but it's for a 1J, anyone know if this same trick can be done to a 2J?
6 years 3 weeks ago #185064 by OT-CNC
Backgear idea is the same.
6 years 3 weeks ago #185074 by OT-CNC
I wonder if there is enough room in your machine to add the encoder to the splined spindle shaft? That would be ideal as you'll have the actual spindle rpm weather in normal gear or backgear....
6 years 3 weeks ago #185075 by rogerfries
I wounder if I could read these supports on the bottom of the Vari-speed belt? Or better press a reluctor wheel (if that's the correct term) on it?
6 years 3 weeks ago #185540 by rootboy
Replied by rootboy on topic Spindle speed sensor for a Bridgeport 2J head
Those spots should be no problem. And since it is steel that your sensor will be reading you won't have to get as close to them with the sensor.
But is twelve pluses per revolution going to suffice? Do you need to know direction as well?
Time to create page: 0.703 seconds
