- Thank you received: 267
Fehlmann Picomax 100 Retrofit
- anfänger
1 year 11 months ago #314304
by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
There is no feedback to linuxcnc,
- Masiwood123
- Thank you received: 93
1 year 9 months ago #318260
by Masiwood123
Replied by Masiwood123 on topic Fehlmann Picomax 100 Retrofit
Hello, can you tell me if limit switches are NO or NC 24vdc...I have a similar machine and I am trying first of all to bring it to the factory control.. it throws out errors that one of the limit switch is on , control allows me to reference
to the z axis, xy will not reach the switches. linear scale on x is also filled with dirt and have to figure out how to clean it. thank you very much
- anfänger
1 year 5 months ago #328442
by anfänger
Replied by anfänger on topic Fehlmann Picomax 100 Retrofit
If its still of interest, the limit switches are normally closed, and go over a relay to the controls.
- anfänger
2 weeks 23 hours ago #350310
by anfänger
Now that most of work which came with moving is done its time to finish the reason why I bought this machine in the first place...
The 4th Axis. The servo is running, so it's time to finish the brake, lubrication and homing. Then using the chance to also install the tool setter.
Also using the chance to update the scematics
now I am waining for some additional pins for the Harting connectors
Then making a small junction box, so the A-Axis can be easily removed
Time to create page: 6.370 seconds
