- Thank you received: 267
Fehlmann Picomax 100 Retrofit
- anfänger
3 years 5 months ago #271288
by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
- anfänger
3 years 5 months ago #272332
by anfänger
I might need some Help,
I've everything wired up and all the hal stuff sorted.
But I am al little bit out of practice the Vers-drives are not working and I'm afraid I have to swap the servos (already looking for a solution).
Anyway I want to test the Spindle and the rest of the machine with the Codes. How di I get the machine homed and idle without moving the machine?
- Thank you received: 7491
3 years 5 months ago #272341
Replied by tommylight on topic Fehlemann Picomax 100 Retrofit
Search for "imediate homing".
Sorry on the phone...
The following user(s) said Thank You: anfänger
- anfänger
3 years 5 months ago #272367
by anfänger
Thanks!
Now I was able to set vfd and after some trouble setting the encoder feedback for the VFD I directly connected the encoder to the mesa card and I got movement. still need some tuning to do. And linuxcnc need full control, at the moment I need to enable the vfd manually once, But the spindle is running.
- anfänger
3 years 5 months ago - 3 years 5 months ago #272434
by anfänger
now the Spindle is running and tested and fixed the codes controlling the column.
I store the column position in an persistent parameter wich allows me to go up first is the position is above the current one.
"just" the servos now and she's ready to run. bit just to be sure I already checked what new servos would fit...
Last edit: 3 years 5 months ago by anfänger.
- anfänger
3 years 3 months ago #276096
by anfänger
Long time no progress, but them I decides to add some new servos, after I found some withe a small form factor suiting the torque and power needed.
So first I removed the old DC drives an pur the four new ones in:
I started with the y-axis by reworking the casting
[/url
after a shirt testfit
finally I widened the bore to fit the new servo
then the y axis was ready
Time to create page: 0.143 seconds
