- Thank you received: 267
Fehlmann Picomax 100 Retrofit
- anfänger
4 years 6 months ago #239921
by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
Thanks, that will help finde replacement. The Z Axis encoder is on an spur gear driving the quill (kind of rack and pinion), so I want at least the same resolution as the existing one. I guess I'll replace the scales and encoder.
many thanks
Patrick
many thanks
Patrick
- RotarySMP
- Thank you received: 595
4 years 6 months ago #240886
by RotarySMP
Replied by RotarySMP on topic Fehlemann Picomax 100 Retrofit
Sorry I nissed that your control had intergrated A/D conversion. Since two channels of my EXE were DOA, I bought replacement 601D EXE's off Ebay.de.They only cost about €60-80 per unit, and only need 5V, rather than 5V and 12V of the original.
I never really worked out the model numbering, so I ended up with one returning the 1µm resolution same as the original. The other one ouputs 5µm resolution. Doesn't make any difference in practice to what I use the MAHO for so far.
Mark
Mark
- anfänger
4 years 6 months ago - 4 years 6 months ago #241185
by anfänger
there ist nothing you have to apologize for.
There are three boxes on ebay for 75€ each.
Cables cut, so I would need to open and rework them. I guess 1F is 5 µm and 5F 1 µm but it's just a guess when the numbers are for the interpolation.
Using them would be cheaper, not sure if quicker, cause I have to redo the connectors from the encoders and rewire the boxes.
Still not really sure what to do.
Change to TTL scales / Encoder oder buying AD boxes.
Changing is roughly triple the cost compared to the AD Boxes.
Which now kicks me to the AD boxes.
Cause the new spindle motor wasn't cheap.
Thanks Patrick
EDIT: F*** it, I bought two of these things for a special deal. This way I can have a look at X and Y an test Z. For U then O can see If I change the encoder or by a third AD box. same for the A-Axis but that for later anyway
Thanks Patrick
Last edit: 4 years 6 months ago by anfänger.
- anfänger
4 years 6 months ago #241324
by anfänger
- anfänger
4 years 6 months ago #241439
by anfänger
not much but, I opened them, they look quite nice.
just to figure out, that I ran out of cable now need to wait for some to arrive. With some luck in can look at it on the weekend.
Also need to think about where to lace the boxes, cause the encoder cables are to short to lay it on the bottom.
I should be able to reroute them and make new entry point in the cabinet.
- RotarySMP
4 years 5 months ago #241901
by RotarySMP
I also have two stand alone boxes and one original EXE channel in operation. I barely notice that one axis has only 5µm resolution, since I only touch off to Hundredths. I have no real expectations of being able to do anything to µm tolerance.
Mark
Mark
Time to create page: 2.090 seconds
