Fehlmann Picomax 100 Retrofit
4 years 9 months ago #233626 by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
Wow many thanks I'll give it a try.
4 years 8 months ago #234043 by anfänger
Didn't tacke the encoders yet, but closes go the control panel:
[img
4 years 8 months ago #234099 by anfänger
I tried to tackle the encoders today and found something odd, even with the corrected color code i can't get a signal.
then I tires to mesure with a multimeter. and all the signal were high even with no wiring present. is this normal?
thanks Patrick
4 years 8 months ago #234122 by anfänger
Still no solution for the encoders, H hipe it's just s Iron jumper and no damage in the Mesa board.
But I added a mount for the hand wheel.
[img
and the panel is painted and wired up. After some testing in halshow I can edit the hal files now
[img
Ohne Titel by Patrick Laible , auf Flickr
4 years 7 months ago #238318 by anfänger
No progress in the last weeks.
Still struggling withe the glas scales and the spindle.
For the Spindle I might have found a solution in form of a 7.5 KW 8000rpm servo with driver from china. This would also solve my encoder problem for rigid tapping. And I can use the analog input from mesa for spindle load. But it's an unplanned investment.
The question is how much do I get for the old spindle motor and drive to ease the pain a bit.
4 years 7 months ago #238320 by RotarySMP
Replied by RotarySMP on topic Fehlemann Picomax 100 Retrofit
thanks Patrick
It is not clear what you are measureing with the multimeter. You really need an oscilloscope to look at the square wave signal which should be coming out of an encoder. I made one of those €20 toy kitself osci from DSO-Shell,  and it is really handy for this stuff.
Time to create page: 1.694 seconds
