Fehlmann Picomax 100 Retrofit
4 years 11 months ago #227500 by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
Damn I looked at the external offset samples and I think they are made for something different. They result in an actual movement of the machine. I could invert the signal, so the machine tries to keep the quill in the same height when the column is moved.
At the moment I don‘t know how I can use an encoder feedback from the column to enhance the capabilities of the machine.
But it is not essential to have the feature to get the machine running. So this will be postponed.
4 years 11 months ago #227735 by anfänger
the Mesa boards are still stuck in customs, so I took the time to bring my Ideas from cardboard to CAD
in the void right to the computer will com a 3d printer holder for the programmable key pads.
Found some 150x12mm aluminium in the shop which I can use for the computer and will be bolted to the existing quite beefy aluminium frame.
in the next days I will prepare the aluminum parts. The cover I sent out for laser cutting out of 3.2 mm aluminum plastic laminate stuff. I the end this might look rather professional compare to my other retrofits (But I am quite sure I find a ways to make it look trashy)
4 years 10 months ago #228353 by anfänger
Not much progress over the last time.
but I printed a sheet to mount the USB ports in and the switch for the control power.
[img
the keypads arrived and I printed a carrier to later mount the on the interface​
[img
[img
Monday I can pick up my mesa boards, the all the hardware, except the laser cut sheet and the hand wheel has arrived.
[img
4 years 10 months ago #228396 by anfänger
With the Mesa boards ready for pickup, I found the motivation to make some progress and made the monitor mount.
This took longer than expected cause the reference switch on the Y-Axis got stuck. But after a some massaging the old machine worked again
[img
The control power supply got a new breaker with an integrated ELCB. Wich is also providing power to the socket on the control panel.
[img
the I Installed the New 24V and 5V power supplies
[img
last step was preparing the din rails and wiring channel for the mesa boards:
[img
Thats all for today.
Cheers Patrick
4 years 10 months ago #228730 by anfänger
the mesa boards are here ant Iv'e tested then
ping for first contact:
Second contact with sserial board
third contact linuxcnc
I am happy! everything seems to run, so its time to bring everything to the machine...
4 years 10 months ago - 4 years 10 months ago #228943 by anfänger
found the time this weekend to finish the control power switch:
this was the last step needed to mount the computer. So I installed the mounting bracket
and then the computer:
Last edit: 4 years 10 months ago by anfänger.
Time to create page: 2.011 seconds
