Fehlmann Picomax 100 Retrofit
  • Moderator
  • Moderator
4 years 10 months ago #229187 by tommylight
Replied by tommylight on topic Fehlemann Picomax 100 Retrofit
A relay wired to Mesa inputs will be enough to show if the power is on or off.
Using one of the 4 analog inputs in mode 1 is also an option to get a rough voltage shown but will require more stuff to isolate from 400V rail, or a THCAD to have the exact voltage shown! :)
4 years 10 months ago #229190 by anfänger
Replied by anfänger on topic Fehlemann Picomax 100 Retrofit
Thanks, I found a relay used to emergency lighting, it will change if one or more of the phases will fail. It's fairly priced and was quickly delivered I'll give it a try.
4 years 10 months ago #229384 by anfänger
Getting closer…
The glass scales need to be wired and the 24v from the terminal block to the Mesa boards.
[img
4 years 10 months ago #229407 by anfänger
You should change your name from begginner to PRO! :)
I can prove you wrong :D!
just finished wiring everything up.
[img
then started the control circuit for testing, only to figure out, I installed 12V Power supply instead of a 24V :D
But Computer and Mesa Boards are running now, and I can start to configure linuxcnc while I am waiting to the power supply
4 years 10 months ago #229481 by anfänger
Setting up hal per remote connection is a lot more comfortable than standing in the workshop.
[img
and when walking trough the shop you can have a look at the VCP.
This machine will be awesome once it's finished
4 years 10 months ago - 4 years 10 months ago #229568 by anfänger
I've written a user space feedback for the front panel.
every button hat a back light, which I can switch and a four digit segment display.
First test with 0.1 Hz refresh rate. so its easy to have a look at it in hal show. later it will run with a 50 hz refresh rate.
Last edit: 4 years 10 months ago by anfänger.
Time to create page: 1.400 seconds
