Deckel FP4 ATC Retrofit
3 years 3 months ago #276495 by andypugh
Replied by andypugh on topic Deckel FP4 ATC Retrofit
I believe the drives are damaged in some way so will not be retaining them. But if I am to keep the current servos I will be needing a 160ish volt DC power supply capable of 2000w or so which isn't cheap from what I'm finding.
If you have the transformer then all you need is a bridge rectifier and some capacitors.
OK, it needs to be suitably sized and rated caps and rectifier, but it's not that hard to do.
Both my machines run on simple rectified mains power.
3 years 3 months ago - 3 years 3 months ago #276522 by Walkahz
Replied by Walkahz on topic Deckel FP4 ATC Retrofit
They are brushed DC motors.
I have attached a photo of the transformer that goes to the current Bosch transistor drives.
I will look into the bridge rectifier option.
Last edit: 3 years 3 months ago by Walkahz. Reason: Added image
3 years 3 months ago #276697 by andypugh
Does it go straight to the drives, or via smoothing caps?
I was going to suggest store.mesanet.com/index.php?route=produc...83_90&product_id=141 for drives but I would expect the 165V on the transformer plate to be Vrms not Vpeak, and that would be 230V once rectified into capacitors.
The following user(s) said Thank You: Walkahz
3 years 3 months ago #276711 by Henk
Replied by Henk on topic Deckel FP4 ATC Retrofit
We have a FP5 with the same drive. It was also faulty when I retrofitted the machine. One axis had blown transistors on the power stage.
Changed the transistors and it has been working ever since, almost every day for 5 years now.
I have the schematics for the drive and I can help with basic fault finding.
The following user(s) said Thank You: tommylight, Walkahz
3 years 3 months ago #276771 by Walkahz
goes straight to the drives. There is a large capacitor inside the drive however.
3 years 3 months ago #276773 by Walkahz
Thanks for the offer.
i found the documentation for the drives and have had a bit of a look through.
Still trying to decide what the best way to go is, at the same time as retrofitting the control i am also trying to get the machine to run off single phase supply. the spindle and accessories are easy enough to do with VFD's being easy to get these days but the drive  transformer will not allow this same approach which is why i am considering if upgrading to modern AC servo's is the most straightforward path. I figure i can resell the existing components to recoup some of the cost.
Time to create page: 0.063 seconds
