Retrofitting HURCO BMC30
1 year 3 weeks ago #335862 by rasmus
Replied by rasmus on topic Retrofitting HURCO BMC30
So i have come some way on the BMC30, adjusted the PID:s a lot and the controller on the Servos as well, where certain I had some balls in the ball nuts where cracked but now I think  it was just the PID:s that were set way to stiff.
But know it seems to work quite good for the moment at leas good enough to progress to the ATC.
I have chosen to go with Probe basic as UI and now i struggle to understand the setup.
My machine that has a 24 pocket carousel ATC that is using a pneumatic motor for the tool changer and grey code encoder. The encoder is a 10 bit encoder which I have hooked up all the bits for and now I am trying to figure out how to digitally connect these to the software but I am not certain how to do this.
Anybody that has any experience how to setup such a ATC or can point me in some kind of direction?
1 year 3 weeks ago - 1 year 3 weeks ago #335874 by tommylight
Replied by tommylight on topic Retrofitting HURCO BMC30
forum.linuxcnc.org/30-cnc-machines/33529...20p-retrofit?start=0
There should be some configs attached there for BMC20, might help you get an idea but i do not think neither use Carousel component.
Edit,
this one uses gray code for 8 tools i think, was way to long ago.
forum.linuxcnc.org/30-cnc-machines/31792...-sbz-130-01-retrofit
Last edit: 1 year 3 weeks ago by tommylight. Reason: more info
Time to create page: 0.057 seconds
