Mesa 7i76e Spindle Reverse
21 Sep 2024 17:14 #310560 by bird-dogman
Mesa 7i76e Spindle Reverse was created by bird-dogman
Having issues trying to run spindle in reverse.  Using backup 7i76e board never used but new.  I'm using HF41F relay and wired per the Mesa drawing.  The relay has been verified and working.   The Dir+ does not trigger the relay +24 volts applied to the other side of the coil.  Whats the best way to verify Dir+ of the 7i76e is working properly.
m5
stopped
    36  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.spindir <== spindle-ccw
    36  bit   IN          FALSE  hm2_7i76e.0.7i76.0.0.spinena <== spindle-enable
    36  float IN              0  hm2_7i76e.0.7i76.0.0.spinout <== spindle-output
m3 s2230
goes forward # 2260-rpm
    36  bit   IN           TRUE  hm2_7i76e.0.7i76.0.0.spinena <== spindle-enable
    36  float IN        0.49952  hm2_7i76e.0.7i76.0.0.spinout <== spindle-output
m4 s2230
goes forward  @22600
    36  bit   IN           TRUE  hm2_7i76e.0.7i76.0.0.spindir <== spindle-ccw
Thanks Jim
  • Moderator
  • Moderator
21 Sep 2024 18:28 #310565 by tommylight
Replied by tommylight on topic Mesa 7i76e Spindle Reverse
What is the Mesa 7i76E Dir- wired to?
21 Sep 2024 22:34 #310576 by bird-dogman
Replied by bird-dogman on topic Mesa 7i76e Spindle Reverse
DIR- and ENA- are wired to the spindle common.
NC is wired to spindle foward
NO is wired to spindle reverse
jim
21 Sep 2024 23:15 #310578 by PCW
Replied by PCW on topic Mesa 7i76e Spindle Reverse
Can you measure the voltage from DIR+ to drive common in both spindle directions?
22 Sep 2024 12:45 #310597 by bird-dogman
Field Voltage 24V
TB4 pin3 Spindle + 5V
Dir+ to drive common( Ena- and Dir-)
CW 12.4V
CCW .2V
jim
22 Sep 2024 13:49 #310602 by PCW
If +12.4V is the open circuit voltage of the  drives direction pin
that would be OK.
22 Sep 2024 15:27 #310605 by bird-dogman
This browser does not support PDFs. Please download the PDF to view it: Download PDF
This is the I have the spindle wired.  The relay never activates.
jim
22 Sep 2024 15:43 #310606 by PCW
Is DIR- connected to 24V common?
22 Sep 2024 16:15 #310607 by bird-dogman
no.
jim
22 Sep 2024 17:42 #310612 by bird-dogman
tied the 24 volt and 5 volt commons together all is well.
Thanks for the help.
jim
Moderators: piasdom
Time to create page: 0.106 seconds
