CINCINATTI MILACRON ARROW 500 (BDS4 + VFS5) WITH MESA 7i77 + 6i25 WITH LINUXCNC
1 year 7 months ago #323490 by UrKibin
Will keep the smart serial cards in mind in the future. Thank you Andy.
1 year 7 months ago #323814 by UrKibin
I tried using MesaCT to generae the ini and hal files but upon loading in linuxcnc, it produces an error.
Debug file information:
Note: Using POSIX realtime
./main.hal:31: Pin 'hm2_5i25.0.7i77.0.4.analogena' does not exist
2243
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f0b2d806000
I do not know how to proceed. Kindly advise.
For information purposes,
Drive 0 - x axis
Drive 1 - y axis
Drive 2 - z axis
Drive 5 - Spindle
Regards,
Kelvin
1 year 7 months ago #323836 by tommylight
1 year 7 months ago #323851 by PCW
What tommylight said.
The channel 4 above makes no sense (on a basic 7I77 configuration the analog channel would be 1)
1 year 7 months ago #324095 by UrKibin
Hi All,
This is the file mesact generated. I change the "channel 4" to channel "1" manually, and it loads to linuxcnc. I'll be wiring the 7i77 to the servo drives to test if the servo drives will respond to the jog commands. Wish me luck.
Regards,
Kelvin
1 year 7 months ago #324120 by PCW
Make sure the drive enables work so a runaway is stopped
before damage occurs. Alternatively, decouple the linear axis
from the motors.
A blind setup has about a 50% chance of a runaway because
either the encoder direction or analog output polarity are reversed
resulting in positive feedback = runaway.
The following user(s) said Thank You: UrKibin
Time to create page: 0.097 seconds
