Any experience with cnc-step machines?
1 year 7 months ago #324444 by mclien
I am considering of buying a cnc milling machine.
 do have good Linux experience and own a Lasercutter (which came as a set to assemble), but I am new to this kind of machines. The cnc-step support confirmed that their milling machines can be run with Linux cnc, but with no support.
I didn't had any resuls with the forum search, hence the question(s):
-Is there experience with this particular machines?
-If not, what kind of information do I need to gather about the controller to get it working?
(here is the information of the site: www.cnc-step.com/5-channel-stepper-motor-controller/ )
Let me know, if this is even the right way to start my information gathering or what a better approach I should do for this.
1 year 7 months ago #324449 by rodw
My recommendation would be to buy a Mesa 7i96s and do it yourself. You will get a better performing machine, probably for the same money without limitations from the parallel port
1 year 7 months ago #324452 by tommylight
1 year 7 months ago #324453 by PCW
Not clear it it actually works with a parallel port.
it has a built in  controller with Ethernet connectivity.
Do they support LinuxCNC directly?
It seems to only have one (LPT like) connector
1 year 7 months ago - 1 year 7 months ago #324454 by mclien
It seems those pics are bit outdated (or I got the wrong link. Here is the official manual:
www.cnc-step.com/wp-content/uploads/2021...-Series_Zero4_EN.pdf
Which clearly has an Ethernet connectivity (page 5 ff).
As for the "direct support" of LinuxCNC: I'm unsure.  This quote from from the specs sheet suggest so:
"Operating System with Software
KinetiC-NC, WINPC-NC, MACH3, EMC, Linux CNC:
Windows / Linux"
Last edit: 1 year 7 months ago by mclien.
1 year 7 months ago - 1 year 7 months ago #324455 by mclien
Well. do you mean to only use that controller and the mentioned machine or use the Mesa 7i96s an build the cnc hardware by myself?
Time to create page: 0.276 seconds
