Maho MH800e Retrofit Project
- Cooped-Up
- Thank you received: 4
07 Oct 2025 19:38 #336046
by Cooped-Up
Maho MH800e Retrofit Project was created by Cooped-Up
I have recently set out (over a year ago) to retrofit my mh800e with linux cnc to make it more user friendly and capable. I had some hurdles with confusion on the mesa cards I am using but I was finally able to make some headway and now have control over the outputs. now I am trying to figure out the mh400e_gearbox program that rotary smp was involved with. if I can figure that out I think I will have a fully functional machine! after I wire everything that is...
here is my debug information
Note: Using POSIX realtime
./my_LinuxCNC_machine.hal:84: Pin 'motion.spindle-speed-in' does not exist
4093
Stopping realtime threads
Unloading hal components
RTAPI_PCI: Unmapped 65536 bytes at 0x7f2494089000
4093
- Thank you received: 5335
07 Oct 2025 19:54 #336048
Replied by PCW on topic Maho MH800e Retrofit Project
When LinuxCNC added the feature to support multiple spindles, the spindle pin names changed.
for example:
becomes
spindle.0.speed-in
for example:
becomes
spindle.0.speed-in
- Cooped-Up
07 Oct 2025 20:03 #336050
by Cooped-Up
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
Noted, that was easy enough to change. I noticed my config had said joint in many places over the word axis. was I wrong to change it all to say axis? new debug text
./my_LinuxCNC_machine.hal:147: Ini variable '[AXIS_0]P' not found.
5235
RTAPI_PCI: Unmapped 65536 bytes at 0x7f09118a1000
5235
- Thank you received: 7497
07 Oct 2025 21:03 #336055
I deleted my reply, twice, as i can not fathom why...
It is a huge machine with several hundreds of KG of moving mass that can easily break you like a twig, yet you allow yourself to change things you do not understand that will ultimately be controlling that machine!!!
Read, ask, do NOT assume.
Replied by tommylight on topic Maho MH800e Retrofit Project
Yes, you are wrong, as proven by the error, AXIS_0 P does not exist, but JOINT_0 P should.was I wrong to change it all to say axis?
- Cooped-Up
07 Oct 2025 21:29 #336058
by Cooped-Up
copy that, I changed it on the premise that the hal file I am referencing has the axis part and that was the only difference. I thought I screwed something up in the config as I recall something about selecting joints over axis. I will change this back. sometimes I overthink thing, with the speed at which you respond I am much better to just ask haha. feel free at any point to call me an idiot, I dont mind
- Cooped-Up
07 Oct 2025 21:57 #336061
by Cooped-Up
okay all the axis are now back to joints. well I changed the ones i copied to joints as they were originally just axis. now I am having this error I am looking into
./my_LinuxCNC_machine.hal:326: Pin 'halui.jog.0.plus' does not exist
8826
RTAPI_PCI: Unmapped 65536 bytes at 0x7ff805e99000
8826
- Cooped-Up
07 Oct 2025 22:01 #336063
by Cooped-Up
is the solution replacing with halui.joint.0.minus? I found that in some research but dont want to do anything rash quite yet...
07 Oct 2025 23:15 #336068
Can we start over?
Upload the hal and ini files here so we can have a look.
Also important as it seems, was this config made before LinuxCNC 2.7 or thereabouts?
What version of LinuxCNC do you have running now?
What Mesa cards are in use?
- Cooped-Up
08 Oct 2025 12:35 #336090
by Cooped-Up
I will add the files when I get home.5i25t 7i77 7i74 7i73 7i84. I have yet to implement the 7i73 but I plan on using it for all of my user interface controls. I did some research and I found all of the updated nomenclature for the version I am running. I got all the old lines updated to what I believe they should be. I finally got the control panel to open without an error. Just need to figure out how to add my external estop to check some of the functions on my bench before I try putting the electronics in my machine.
- Cooped-Up
08 Oct 2025 23:30 #336126
by Cooped-Up
ok here are my files and the reference file for the mh400e which was made about 5 or more years ago I think. I made a bunch of configs so I am sorry the name is the default I need to change it. again I think this is mostly working now short of a few bugs I need to test some things out and move towards wiring things to the mill
Moderators: piasdom
Time to create page: 0.156 seconds
