retrofitting a Proxon for coin die milling
6 months 2 weeks ago #345560 by rodw
Some people run the pi4b with a slower servo thread eg 2 ms or 1.5 Ms with mesa cards
run:
latency-histogram  --nobase --nobase 1000 --show
and share the screenshot here. the 4b is marginally OK but 126us is fine for a Mesa card at 1 ms servo thread.
6 months 2 weeks ago #345565 by NWE
ballscrews ar primary because the original threads in brass nuts have quite some deadway.
Just so you know, LinuxCNC has backlash compensation parameters. That said, I'm not real sure milling dies would go well with backlash. I used to have a diy CNC router with cheap ACME screws, running LinuxCNC + parport + microsteppers. I did more drilling than routering with it, drilling the thru-holes in home-brew PCBs. On that machine, backlash compensation was the ticket.
6 months 2 weeks ago #345651 by mclien
Here are the 2 screenshots of the Pi. One whithout anything but the Desktop running, one with glxgears running (window resized to about the double).
6 months 2 weeks ago #345655 by andypugh
Pi5 might work better. But given that you have a 7i96 the Pi4 should work fine with the latency shown. (Just don't watch YouTube while milling)
6 months 2 weeks ago #345661 by rodw
See if you can add isolcpus=3 to your kernel boot file. I have done it on a pi but can't remember how
It should improve latency.
6 months 2 weeks ago #345678 by 3404gerber
As rodw said, try to add isolcpus=3 or even isolcpus=2,3 in your /boot/firmware/cmdline.txt
Also, I did some tests with Remora over ethernet on a PI400 and you should follow rodw's video to adjust the ethernet connection to your mesa card.
Time to create page: 0.071 seconds
