DIY CNC
3 months 2 days ago - 3 months 2 days ago #348211 by timo
Replied by timo on topic DIY CNC
I am not sure if Linux CNC is really cheaper than GRBL.
www.grbl.org/single-post/a-peek-at-the-picocnc  This is an example based on the Raspberry Pi Pico, all documented and possible to recreate "in the flesh". I bought the Pico boards for like 3€ a piece. The base board was more expensive, but not too crazy.
  • slow simple 3 axis machine without linear scales or rotary encoders probably works just fine with the GRBL
    • When I think of adding things "slaved axis", "linear scales", "automatic tool changer" I would go for LinuxCNC
Last edit: 3 months 2 days ago by timo.
3 months 2 days ago #348214 by djdelorie
Replied by djdelorie on topic DIY CNC
The OP implied he already had a PC to use, which you'd need for GRBL anyway (unless you added an LCD, buttons, and an sdcard), so adding a parallel breakout board is about $10, compared to the $4 for the pico and whatever the picocnc costs (assuming you can buy it, I couldn't find one for sale, but web site says "retired", but historically $29 assembled). You need the same stepper drivers either way.
A Mesa board is way more expensive, yes, but you get a lot more for your money.
The following user(s) said Thank You: timo
3 months 2 days ago - 3 months 2 days ago #348215 by timo
Exactly! The PC (raspberry Pi or similar), power supplies and stepper (or servo drivers) can be basically the same. What I think is that the mesa card is not worth it, when you stay with open loop stepper motors and the mechanical system is not made for high speeds. But once you start using the I/O and Encoder inputs it is a real help to have a system that is easy to use, supported and works (happy customer of Mesa Plug n go kit).
For the picoCNC I paid roughly (guessing) 130-140€. Some things come with minimum quantities, others are discounted. It ends up at approx. 30€ a piece +-. I would have just bought the successor of it for 50$, but shipping would have doubled the price. To me it was more about the assembly challenge than the actual need for it. But there are "ready to go" options.
One aspect is that a 10 mm carbide endmill will cost roughly the same.
So for metal working the tooling and material quickly gets in regions where a Mesa card is really my least problem :-) and I bought a 2nd Mesa card after the first one.
#no advertisement just random pictures.
3 months 2 days ago #348217 by djdelorie
I agree - for someone getting started, pay the $10 and get started.  I did that.  Just understand that you may outgrow the $10 option and need to get the $150 option (or in my case, the $220 option, and I'm looking at adding two more Mesa cards in the future).  The Mesa cards are in a completely different category of "cnc boards" and - if you need them - they're worth every penny, and cheap compared to the rest of the stuff you'll get.  But you don't need them to get started.
I think my only point is, if you already have a PC with a parallel port (rare these days), the $10 breakout is a better option than anything RPI-based, because it lets you get started with LinuxCNC, which has a better growth path than GRBL.  Assuming growth is a goal, of course ;-)
As for assembly challenges...  www.delorie.com/photos/cnc2/PXL_20231229_210308596.html (and it's gotten worse since then)
The following user(s) said Thank You: tommylight, timo
3 months 2 days ago #348218 by tommylight
Replied by tommylight on topic DIY CNC
I absolutely agree, thank you.
3 months 2 days ago - 3 months 2 days ago #348234 by Logthor
Replied by Logthor on topic DIY CNC
File Name: BBU_part_V...sion.zip
File Size:18.56 KB
My only concern regarding using my parallel port computer with a breakout board is the delay (hence why I was considering the mesa card). Hypothetically, let's say my jitter isn't a problem. Will my experience making chips be the same as with a mesa card? I want to make some pretty complex parts and am concerned that any amount of jitter could make that impossible. I've attached an STL file of a part that I want to make for a friend. Could this be possible using a parallel port, or should I just spring for the more expensive card?
Last edit: 3 months 2 days ago by Logthor.
Time to create page: 0.097 seconds
