DIY CNC
3 months 4 days ago - 3 months 3 days ago #348144 by Logthor
Replied by Logthor on topic DIY CNC
My machine is only a 3-axis machine. I'm not sure of how much more I/O I really need. I plan on using the old Dell for LinuxCNC, so I really don't need to worry about having a free Ethernet port. Can you use a Mesa card and a WiFi card at the same time? If not, I'm fine with using the old sneakernet method.
Last edit: 3 months 3 days ago by Logthor.
3 months 4 days ago #348145 by djdelorie
Replied by djdelorie on topic DIY CNC
my machine was "only" a three axis machine too, but I just kept adding to it... ;-)
Mesa and Wifi should be OK; my machine has two ethernet ports. You just don't want mesa packets on the same wire as other packets.
3 months 3 days ago #348147 by Logthor
Different question: if I want to control my spindle's speed, I do this through software, right? My Sherline mill's speed control uses a 0-7V range to control its speed using a potentiometer.
3 months 3 days ago #348148 by djdelorie
The 7i96S board has an analog spindle out which should work for that purpose - it's implemented as an isolated digital potentiometer.
3 months 3 days ago #348149 by Logthor
gotcha, so I would just adjust it in LinuxCNC?
3 months 3 days ago #348150 by djdelorie
Yup! It may take some fiddling to get the speed you asked for to match the speed you get, but it should at least "just work"
The following user(s) said Thank You: tommylight, Logthor
Time to create page: 0.075 seconds
