- Thank you received: 5
Yes, I have started a video series on a parallel port control board from scratch. This is the first of 3Cool, I will probably go with the parallel port in the meantime, then. I should have enough I/O with the parallel port to control my x, y, and z axes and my spindle, right? I'm just looking for a yes or no regarding the timing issue and whether it would be a problem or not in making that part (assuming I have 15000-20000 nanoseconds jitter).
Glad someone else looked!@logthor: The stl you posted, will be a nightmare to machine
Those things are magnificent and make tapping possible on low torque/power spindles.... but thread milling solves the thread cutting dilema on all machines and is much easier on small machines.
