× Forum Header
emc2 don't start ....
11 Aug 2011 15:08 #12424 by thor1966
emc2 don't start .... was created by thor1966
an italian man in combact with EMC2 .......
Loading real time OS, RTAPI,and hal_lib modules
Realtime system did not load
shutting down and cleaning up EMC2
killing task emcsvr .....
what' is this ?????????????
11 Aug 2011 15:14 #12425 by BigJohnT
Replied by BigJohnT on topic Re:emc2 don't start ....
Not enough information.
What config are you trying to run?
Attach the complete error message to your reply using the Browse button for files.
11 Aug 2011 15:26 #12426 by thor1966
Replied by thor1966 on topic Re:emc2 don't start ....
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/domenico/emc2/configs/stepper'
Machine configuration file is 'stepper_mm.ini'
INIFILE=/home/domenico/emc2/configs/stepper/stepper_mm.ini
PARAMETER_FILE=stepper.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1813
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1813
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001dff0000 (usable)
[ 0.000000] BIOS-e820: 000000001dff0000 - 000000001dff8000 (ACPI data)
[ 0.000000] BIOS-e820: 000000001dff8000 - 000000001e000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000ffee0000 - 00000000fff0ffff (reserved)
[ 0.000000] BIOS-e820: 00000000fffc0000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working around it.
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0x1dff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FF0000000 write-back
[ 0.000000] 1 base 010000000 mask FF8000000 write-back
[ 0.000000] 2 base 018000000 mask FFC000000 write-back
[ 0.000000] 3 base 01C000000 mask FFE000000 write-back
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 base 0E0000000 mask FFC000000 write-combining
[ 0.000000] 7 base 0E0000000 mask FFC000000 write-combining
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] Scanning 0 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000010000 (reserved)
[ 0.000000] modified: 0000000000010000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000001dff0000 (usable)
[ 0.000000] modified: 000000001dff0000 - 000000001dff8000 (ACPI data)
[ 0.000000] modified: 000000001dff8000 - 000000001e000000 (ACPI NVS)
[ 0.000000] modified: 00000000ffee0000 - 00000000fff0ffff (reserved)
[ 0.000000] modified: 00000000fffc0000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000001dff0000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001dc00000 page 2M
[ 0.000000] 001dc00000 - 001dff0000 page 4k
[ 0.000000] kernel direct mapping tables up to 1dff0000 @ 10000-15000
[ 0.000000] RAMDISK: 15bb1000 - 16833209
[ 0.000000] ACPI: RSDP 000fa2f0 00014 (v00 AMI )
[ 0.000000] ACPI: RSDT 1dff0000 00028 (v01 AMIINT SiS645XX 00000010 MSFT 0100000B)
[ 0.000000] ACPI: FACP 1dff0030 00081 (v02 AMIINT SiS645XX 00000011 MSFT 0100000B)
[ 0.000000] ACPI: DSDT 1dff00c0 033F6 (v01 SiS 645 00001000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 1dff8000 00040
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 479MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1dff0000
[ 0.000000] low ram: 0 - 1dff0000
[ 0.000000] node 0 low ram: 00000000 - 1dff0000
[ 0.000000] node 0 bootmap 00011000 - 00014c00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 001dff0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [0015bb1000 - 0016833209] RAMDISK ==> [0015bb1000 - 0016833209]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b4294] BRK ==> [00008b1000 - 00008b4294]
[ 0.000000] #7 [0000010000 - 0000011000] PGTABLE ==> [0000010000 - 0000011000]
[ 0.000000] #8 [0000011000 - 0000015000] BOOTMAP ==> [0000011000 - 0000015000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001dff0
[ 0.000000] HighMem 0x0001dff0 -> 0x0001dff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001dff0
[ 0.000000] On node 0 totalpages: 122751
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 928 pages used for memmap
[ 0.000000] Normal zone: 117840 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 1e000000 (gap: 1e000000:e1ee0000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1400000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121791
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=3d1c4784-3c20-4217-8340-bd084e26d2b5 ro quiet splash
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2456960 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 463204k/491456k available (4539k kernel code, 27460k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xde7f0000 - 0xff7fe000 ( 528 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xddff0000 ( 479 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1992.214 MHz processor.
[ 0.004010] Calibrating delay loop (skipped), value calculated using timer frequency.. 3984.42 BogoMIPS (lpj=7968856)
[ 0.004052] Security Framework initialized
[ 0.004098] AppArmor: AppArmor initialized
[ 0.004116] Mount-cache hash table entries: 512
[ 0.004394] Initializing cgroup subsys ns
[ 0.004406] Initializing cgroup subsys cpuacct
[ 0.004417] Initializing cgroup subsys memory
[ 0.004439] Initializing cgroup subsys devices
[ 0.004446] Initializing cgroup subsys freezer
[ 0.004452] Initializing cgroup subsys net_cls
[ 0.004501] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.004510] CPU: L2 cache: 512K
[ 0.004515] CPU: Hyper-Threading is disabled
[ 0.004526] mce: CPU supports 4 MCE banks
[ 0.004561] Performance Events: no PMU driver, software events only.
[ 0.004578] Checking 'hlt' instruction... OK.
[ 0.021872] SMP alternatives: switching to UP code
[ 0.038551] Freeing SMP alternatives: 31k freed
[ 0.038598] ACPI: Core revision 20090903
[ 0.051057] ACPI: setting ELCR to 0200 (from 1820)
[ 0.052018] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.052033] ftrace: allocating 21003 entries in 42 pages
[ 0.069228] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.069236] weird, boot CPU (#0) not listed by the BIOS.
[ 0.069239] SMP motherboard not detected.
[ 0.069244] Local APIC not detected. Using dummy APIC emulation.
[ 0.069247] SMP disabled
[ 0.069648] Brought up 1 CPUs
[ 0.069655] Total of 1 processors activated (3984.42 BogoMIPS).
[ 0.070154] CPU0 attaching NULL sched-domain.
[ 0.070490] devtmpfs: initialized
[ 0.071166] regulator: core version 0.5
[ 0.071269] NET: Registered protocol family 16
[ 0.071514] EISA bus registered
[ 0.071532] ACPI: bus type pci registered
[ 0.076008] PCI: PCI BIOS revision 2.10 entry at 0xfdb01, last bus=1
[ 0.076013] PCI: Using configuration type 1 for base access
[ 0.077550] bio: create slab <bio-0> at 0
[ 0.078489] ACPI: EC: Look up EC in DSDT
[ 0.087586] ACPI: Interpreter enabled
[ 0.087591] ACPI: (supports S0 S5)
[ 0.087612] ACPI: Using PIC for interrupt routing
[ 0.096340] ACPI: Power Resource [URP1] (off)
[ 0.096402] ACPI: Power Resource [URP2] (off)
[ 0.096456] ACPI: Power Resource [FDDP] (off)
[ 0.096509] ACPI: Power Resource [LPTP] (off)
[ 0.096736] ACPI: No dock devices found.
[ 0.097509] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.097602] pci 0000:00:00.0: reg 10 32bit mmio: [0xe0000000-0xe3ffffff]
[ 0.097820] pci 0000:00:02.0: Enabling SiS 96x SMBus
[ 0.097890] pci 0000:00:02.1: reg 20 io port: [0xc00-0xc1f]
[ 0.097945] pci 0000:00:02.2: reg 10 32bit mmio: [0xdfffa000-0xdfffafff]
[ 0.098027] pci 0000:00:02.3: reg 10 32bit mmio: [0xdfffb000-0xdfffbfff]
[ 0.098137] pci 0000:00:02.5: reg 20 io port: [0xff00-0xff0f]
[ 0.098217] pci 0000:00:02.7: reg 10 io port: [0xdc00-0xdcff]
[ 0.098229] pci 0000:00:02.7: reg 14 io port: [0xd800-0xd87f]
[ 0.098297] pci 0000:00:02.7: PME# supported from D3hot D3cold
[ 0.098305] pci 0000:00:02.7: PME# disabled
[ 0.098359] pci 0000:00:03.0: reg 10 io port: [0xd400-0xd4ff]
[ 0.098371] pci 0000:00:03.0: reg 14 32bit mmio: [0xdfff9000-0xdfff9fff]
[ 0.098410] pci 0000:00:03.0: reg 30 32bit mmio pref: [0xdffc0000-0xdffdffff]
[ 0.098440] pci 0000:00:03.0: supports D1 D2
[ 0.098444] pci 0000:00:03.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.098451] pci 0000:00:03.0: PME# disabled
[ 0.098570] pci 0000:01:00.0: reg 10 32bit mmio pref: [0xd0000000-0xd7ffffff]
[ 0.098581] pci 0000:01:00.0: reg 14 32bit mmio: [0xdfee0000-0xdfefffff]
[ 0.098592] pci 0000:01:00.0: reg 18 io port: [0xbc00-0xbc7f]
[ 0.098642] pci 0000:01:00.0: supports D1 D2
[ 0.098701] pci 0000:00:01.0: bridge io port: [0xb000-0xbfff]
[ 0.098709] pci 0000:00:01.0: bridge 32bit mmio: [0xdfe00000-0xdfefffff]
[ 0.098718] pci 0000:00:01.0: bridge 32bit mmio pref: [0xcfc00000-0xdfcfffff]
[ 0.098732] pci_bus 0000:00: on NUMA node 0
[ 0.098741] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.100892] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 *5 7 10 11 12 14 15)
[ 0.101099] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.101303] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.101506] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 10 11 12 14 15) *0, disabled.
[ 0.101710] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 10 11 *12 14 15)
[ 0.101913] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 10 *11 12 14 15)
[ 0.102114] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 7 10 11 12 14 15)
[ 0.102317] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 10 11 *12 14 15)
[ 0.102550] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.102556] vgaarb: loaded
[ 0.102831] SCSI subsystem initialized
[ 0.102997] libata version 3.00 loaded.
[ 0.103150] usbcore: registered new interface driver usbfs
[ 0.103176] usbcore: registered new interface driver hub
[ 0.103228] usbcore: registered new device driver usb
[ 0.103493] ACPI: WMI: Mapper loaded
[ 0.103499] PCI: Using ACPI for IRQ routing
[ 0.103756] NetLabel: Initializing
[ 0.103761] NetLabel: domain hash size = 128
[ 0.103764] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.103793] NetLabel: unlabeled traffic allowed by default
[ 0.103867] Switching to clocksource tsc
[ 0.104001] AppArmor: AppArmor Filesystem Enabled
[ 0.104001] pnp: PnP ACPI init
[ 0.104001] ACPI: bus type pnp registered
[ 0.110594] pnp: PnP ACPI: found 12 devices
[ 0.110601] ACPI: ACPI bus type pnp unregistered
[ 0.110612] PnPBIOS: Disabled by ACPI PNP
[ 0.145539] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.145547] pci 0000:00:01.0: IO window: 0xb000-0xbfff
[ 0.145557] pci 0000:00:01.0: MEM window: 0xdfe00000-0xdfefffff
[ 0.145566] pci 0000:00:01.0: PREFETCH window: 0xcfc00000-0xdfcfffff
[ 0.145597] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.145603] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.145609] pci_bus 0000:01: resource 0 io: [0xb000-0xbfff]
[ 0.145613] pci_bus 0000:01: resource 1 mem: [0xdfe00000-0xdfefffff]
[ 0.145618] pci_bus 0000:01: resource 2 pref mem [0xcfc00000-0xdfcfffff]
[ 0.145697] NET: Registered protocol family 2
[ 0.145889] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.146399] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.146568] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.146715] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.146720] TCP reno registered
[ 0.146873] NET: Registered protocol family 1
[ 0.146978] pci 0000:01:00.0: Boot video device
[ 0.147396] Scanning for low memory corruption every 60 seconds
[ 0.147593] audit: initializing netlink socket (disabled)
[ 0.147622] type=2000 audit(1313159288.144:1): initialized
[ 0.157122] Trying to unpack rootfs image as initramfs...
[ 0.168702] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.176720] VFS: Disk quotas dquot_6.5.2
[ 0.176926] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.178146] fuse init (API version 7.13)
[ 0.178316] msgmni has been set to 905
[ 0.178792] alg: No test for stdrng (krng)
[ 0.178929] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.178937] io scheduler noop registered
[ 0.178941] io scheduler anticipatory registered
[ 0.178945] io scheduler deadline registered
[ 0.179017] io scheduler cfq registered (default)
[ 0.179220] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.179267] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.179412] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 0.179423] ACPI: Power Button [PWRB]
[ 0.179544] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[ 0.179559] ACPI: Sleep Button [SLPB]
[ 0.179653] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.179659] ACPI: Power Button [PWRF]
[ 0.182557] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.182731] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.182888] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.183433] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.183652] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.188586] isapnp: Scanning for PnP cards...
[ 0.195816] brd: module loaded
[ 0.196730] loop: module loaded
[ 0.196979] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.197278] pata_sis 0000:00:02.5: version 0.5.2
[ 0.200662] scsi0 : pata_sis
[ 0.244555] scsi1 : pata_sis
[ 0.246245] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xff00 irq 14
[ 0.246251] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xff08 irq 15
[ 0.246982] Fixed MDIO Bus: probed
[ 0.247058] PPP generic driver version 2.4.2
[ 0.247210] tun: Universal TUN/TAP device driver, 1.6
[ 0.247214] tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
[ 0.247423] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.247458] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.247794] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 12
[ 0.247800] PCI: setting IRQ 12 as level-triggered
[ 0.247809] ohci_hcd 0000:00:02.2: PCI INT D -> Link[LNKE] -> GSI 12 (level, low) -> IRQ 12
[ 0.247848] ohci_hcd 0000:00:02.2: OHCI Host Controller
[ 0.247943] ohci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 1
[ 0.247989] ohci_hcd 0000:00:02.2: irq 12, io mem 0xdfffa000
[ 0.338146] usb usb1: configuration #1 chosen from 1 choice
[ 0.338210] hub 1-0:1.0: USB hub found
[ 0.338237] hub 1-0:1.0: 3 ports detected
[ 0.338710] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 12
[ 0.338720] ohci_hcd 0000:00:02.3: PCI INT A -> Link[LNKH] -> GSI 12 (level, low) -> IRQ 12
[ 0.338756] ohci_hcd 0000:00:02.3: OHCI Host Controller
[ 0.338859] ohci_hcd 0000:00:02.3: new USB bus registered, assigned bus number 2
[ 0.338894] ohci_hcd 0000:00:02.3: irq 12, io mem 0xdfffb000
[ 0.430061] usb usb2: configuration #1 chosen from 1 choice
[ 0.430124] hub 2-0:1.0: USB hub found
[ 0.430163] hub 2-0:1.0: 3 ports detected
[ 0.430280] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.430483] PNP: PS/2 Controller [PNP0303:PS2K] at 0x60,0x64 irq 1
[ 0.430488] PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.430726] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.431235] mice: PS/2 mouse device common for all mice
[ 0.434926] rtc_cmos 00:02: RTC can wake from S4
[ 0.435112] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.435145] rtc0: alarms up to one month, 114 bytes nvram
[ 0.435403] device-mapper: uevent: version 1.0.3
[ 0.435680] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
[ 0.437298] ata1.00: ATA-7: Maxtor 6E040L0, NAR61590, max UDMA/133
[ 0.437306] ata1.00: 80293248 sectors, multi 16: LBA
[ 0.440533] device-mapper: multipath: version 1.1.0 loaded
[ 0.440543] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.441005] EISA: Probing bus 0 at eisa.0
[ 0.441055] EISA: Detected 0 cards.
[ 0.441063] cpuidle: using governor ladder
[ 0.441067] cpuidle: using governor menu
[ 0.441845] TCP cubic registered
[ 0.442083] NET: Registered protocol family 10
[ 0.442860] lo: Disabled Privacy Extensions
[ 0.443410] NET: Registered protocol family 17
[ 0.443505] Using IPI No-Shortcut mode
[ 0.443742] registered taskstats version 1
[ 0.444286] rtc_cmos 00:02: setting system clock to 2011-08-12 14:28:09 UTC (1313159289)
[ 0.444294] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.444297] EDD information not available.
[ 0.452886] ata1.00: configured for UDMA/100
[ 0.454386] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.783725] usb 1-1: new low speed USB device using ohci_hcd and address 2
[ 0.871778] isapnp: No Plug & Play device found
[ 0.872121] scsi 0:0:0:0: Direct-Access ATA Maxtor 6E040L0 NAR6 PQ: 0 ANSI: 5
[ 0.872490] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 0.872830] sd 0:0:0:0: [sda] 80293248 512-byte logical blocks: (41.1 GB/38.2 GiB)
[ 0.872928] sd 0:0:0:0: [sda] Write Protect is off
[ 0.872934] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 0.872984] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 0.873276] sda:
[ 1.015248] usb 1-1: configuration #1 chosen from 1 choice
[ 1.036484] ata2.00: ATAPI: HL-DT-ST DVDRAM GSA-4167B, DL11, max UDMA/33
[ 1.052491] ata2.00: configured for UDMA/33
[ 1.060418] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GSA-4167B DL11 PQ: 0 ANSI: 5
[ 1.077942] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 1.077956] Uniform CD-ROM driver Revision: 3.20
[ 1.078269] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.078425] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.118075] Freeing initrd memory: 12808k freed
[ 1.566557] sda1 sda2 < sda5 >
[ 1.585683] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.585720] Freeing unused kernel memory: 620k freed
[ 1.586947] Write protecting the kernel text: 4540k
[ 1.586991] Write protecting the kernel read-only data: 1668k
[ 1.638268] udev: starting version 151
[ 2.058644] Floppy drive(s): fd0 is 1.44M
[ 2.060373] vga16fb: initializing
[ 2.060388] vga16fb: mapped to 0xc00a0000
[ 2.060710] fb0: VGA16 VGA frame buffer device
[ 2.062085] Linux agpgart interface v0.103
[ 2.076094] FDC 0 is a post-1991 82077
[ 2.092302] sis900.c: v1.08.10 Apr. 2 2006
[ 2.092740] ACPI: PCI Interrupt Link [LNKG] enabled at IRQ 5
[ 2.092747] PCI: setting IRQ 5 as level-triggered
[ 2.092756] sis900 0000:00:03.0: PCI INT A -> Link[LNKG] -> GSI 5 (level, low) -> IRQ 5
[ 2.094099] 0000:00:03.0: Realtek RTL8201 PHY transceiver found at address 1.
[ 2.108042] 0000:00:03.0: Using transceiver found at address 1 as default
[ 2.158731] usbcore: registered new interface driver hiddev
[ 2.161934] eth0: SiS 900 PCI Fast Ethernet at 0xd400, IRQ 5, 00:07:95:fe:eb:b9
[ 2.161996] agpgart-sis 0000:00:00.0: SiS chipset [1039/0650]
[ 2.203421] input: HID 1241:1166 as /devices/pci0000:00/0000:00:02.2/usb1/1-1/1-1:1.0/input/input5
[ 2.203876] generic-usb 0003:1241:1166.0001: input,hidraw0: USB HID v1.10 Mouse [HID 1241:1166] on usb-0000:00:02.2-1/input0
[ 2.203950] usbcore: registered new interface driver usbhid
[ 2.204335] usbhid: v2.6:USB HID core driver
[ 2.209615] agpgart-sis 0000:00:00.0: AGP aperture is 64M @ 0xe0000000
[ 2.274888] Console: switching to colour frame buffer device 80x30
[ 2.784205] xor: automatically using best checksumming function: pIII_sse
[ 2.804023] pIII_sse : 2608.000 MB/sec
[ 2.804028] xor: using function: pIII_sse (2608.000 MB/sec)
[ 2.837024] device-mapper: dm-raid45: initialized v0.2594b
[ 3.062254] EXT4-fs (sda1): mounted filesystem with ordered data mode
[ 10.062988] Adding 1395704k swap on /dev/sda5. Priority:-1 extents:1 across:1395704k
[ 10.181803] udev: starting version 151
[ 10.424401] sis96x_smbus 0000:00:02.1: SiS96x SMBus base address: 0x0c00
[ 10.424414] ACPI: resource 0000:00:02.1 [0xc00-0xc1f] conflicts with ACPI region SMRG [0xc00-0xc1f]
[ 10.424419] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 10.424987] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 10.983493] parport_pc 00:09: reported by Plug and Play ACPI
[ 10.983607] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 11.092815] type=1505 audit(1313159300.147:2): operation="profile_load" pid=471 name="/sbin/dhclient3"
[ 11.093779] type=1505 audit(1313159300.147:3): operation="profile_load" pid=471 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 11.094239] type=1505 audit(1313159300.147:4): operation="profile_load" pid=471 name="/usr/lib/connman/scripts/dhclient-script"
[ 11.251108] lp0: using parport0 (interrupt-driven).
[ 11.302572] ppdev: user-space parallel port driver
[ 11.453530] gameport: NS558 PnP Gameport is pnp00:0a/gameport0, io 0x201, speed 552kHz
[ 11.838714] ACPI: PCI Interrupt Link [LNKF] enabled at IRQ 11
[ 11.838723] PCI: setting IRQ 11 as level-triggered
[ 11.838732] Intel ICH 0000:00:02.7: PCI INT C -> Link[LNKF] -> GSI 11 (level, low) -> IRQ 11
[ 12.180149] intel8x0_measure_ac97_clock: measured 53145 usecs (2557 samples)
[ 12.180157] intel8x0: clocking to 48000
[ 12.426664] type=1505 audit(1313159301.479:5): operation="profile_load" pid=657 name="/usr/share/gdm/guest-session/Xsession"
[ 12.453232] type=1505 audit(1313159301.507:6): operation="profile_replace" pid=658 name="/sbin/dhclient3"
[ 12.454070] type=1505 audit(1313159301.507:7): operation="profile_replace" pid=658 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 12.454527] type=1505 audit(1313159301.507:8): operation="profile_replace" pid=658 name="/usr/lib/connman/scripts/dhclient-script"
[ 12.533469] type=1505 audit(1313159301.587:9): operation="profile_load" pid=662 name="/usr/bin/evince"
[ 12.585830] eth0: Media Link Off
[ 12.591998] type=1505 audit(1313159301.643:10): operation="profile_load" pid=662 name="/usr/bin/evince-previewer"
[ 12.596411] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 12.640409] type=1505 audit(1313159301.695:11): operation="profile_load" pid=662 name="/usr/bin/evince-thumbnailer"
[ 81.369975] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 114.302083] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 333.415875] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 403.106400] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 1267.607882] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
e' tutto .....:blush:
11 Aug 2011 16:09 #12427 by BigJohnT
It is much better if you save the info as a text file and attach the file instead of having a super long message...
11 Aug 2011 16:12 #12428 by BigJohnT
How did you install EMC?
12 Aug 2011 05:07 #12445 by thor1966
with a live -cd downloaded from ubuntu- comunity ...
sorry for the very long message
12 Aug 2011 10:41 #12451 by Rick G
Replied by Rick G on topic Re:emc2 don't start ....
Have you looked here...
wiki.linuxcnc.org/emcinfo.pl?TroubleShooting
Were you able to run a latency test?
Rick G
12 Aug 2011 11:41 #12454 by BigJohnT
Which config are you trying to run?
12 Aug 2011 12:47 #12457 by thor1966
resolved. Pin wrong for digitizing error during config
01 Jul 2012 16:21 #21472 by jy76
Replied by jy76 on topic Re:emc2 don't start ....
quiet splash lapic in grub the wiki tells how to do this
Time to create page: 0.197 seconds
