- Configuring LinuxCNC
- Configuration Tools
- StepConf Wizard
- 2m982 stepper driver settings for emc2 wizard
Forum Header
- garymo
03 Oct 2011 06:04 #13618
by garymo
2m982 stepper driver settings for emc2 wizard was created by garymo
Hi Can anyone help me with the above stepper driver 2m982 7.2 amp settings for stepconf
i am after are
step time?
Step Space?
Direction Hold?
Direction Setup?
I have a latency of about 40000
The driver has settings for 2-64 microstep resolution and the motors are 1.8 deg currently set at 2000 steps per rev
Any help would be much appreciated
Regards Gary
i am after are
step time?
Step Space?
Direction Hold?
Direction Setup?
Regards Gary
- cncbasher
- Thank you received: 288
03 Oct 2011 07:26 #13619
by cncbasher
Replied by cncbasher on topic Re:2m982 stepper driver settings for emc2 wizard
these are popular stepper drives , distributed under many names and are quite generic , these settings work for me
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 15200
setp stepgen.1.dirsetup 15200
- Thank you received: 4994
03 Oct 2011 10:02 #13624
Replied by andypugh on topic Re:2m982 stepper driver settings for emc2 wizard
cncbasher wrote:
I think that step 1 space 0 is only valid for parport systems, and if "reset" is active (in which case the reset-time is the actual step time)these are popular stepper drives , distributed under many names and are quite generic , these settings work for me
- StepConf Wizard
Time to create page: 0.052 seconds
