Forum Header
reversing motor travel?
- jhtitan
28 Dec 2009 03:23 #1404
by jhtitan
reversing motor travel? was created by jhtitan
how do i reverse the travel in a motor in EMC2 without inverting it in the stepper config wiz?
inverting the motor disables my idle current limiting, but my X and Z are traveling backwards.
thanks
Jon
thanks
Jon
- alex_joni
28 Dec 2009 09:31 #1405
by alex_joni
Replied by alex_joni on topic Re:reversing motor travel?
You can put a negative sign on the scale. Not sure you can do that from the stepconf wizard, but editing the ini file directly should be easy.
find [AXIS_0] (X) and [AXIS_2] (Z) and change the sign for SCALE
Regards,
Alex
Regards,
Alex
- tenaja
- Thank you received: 5
05 Jan 2010 01:14 #1442
by tenaja
Replied by tenaja on topic Re:reversing motor travel?
You can swap any two stepper wires, too. Then there are no s/w changes.
- jhtitan
05 Jan 2010 13:15 #1444
by jhtitan
Replied by jhtitan on topic Re:reversing motor travel?
I found that just changing the motor steps per/rev from 200 to -200 reversed the motors also in the stepper config wizard.
thanks for the help
Jon
thanks for the help
Jon
