× Forum Header
use digital input for machine-power
12 Jan 2010 21:40 #1505 by gironymo
use digital input for machine-power was created by gironymo
hello,
i'm trying to connect my isel-controller to emc. so i designed a new controllerboard - with some troubles ...
i found out how i can monitor my lpt-port today. it works great and i found the needed input for the emergency stop.
i found also the pin which tells emc that the machine is powered on but i can not find a signal which i can use for setting the state in emc.
here is my configuration for my inputs:
pin 10: ref. switch x
pin 11: ref. switch y
pin 12: ref. switch z
pin 13: emergency stop ext.
pin 15: --> power on (i used digital input 0)
the normal way to use the isel-machine is like emc: power on the main switch, release emergency stop (pin 13), power on the controller (pin 15)
is ther any possibility to tell emc that the digital input 0 is used for power on?
i hope, you know what i mean and sorry about my english ... i'm from austria ;)
greetings
markus
12 Jan 2010 23:36 #1506 by BigJohnT
Replied by BigJohnT on topic Re:use digital input for machine-power
Take a look at motion.enable here:
www.linuxcnc.org/docview/html//man/man9/motion.9.html
or halui.machine.on (bit, in) - pin for requesting machine on
www.linuxcnc.org/docview/html//gui_halui.html#r1_2_9
13 Jan 2010 06:00 #1510 by gironymo
Replied by gironymo on topic Re:use digital input for machine-power
hi john,
thanks for your answer. it looks like that is what i need.
is there any documentation which describes the single points (what ist flood, jog, joint ...).
and i have another question: how can i set the toolchange-position?
thanks a lot
markus
14 Jan 2010 18:39 - 14 Jan 2010 18:44 #1512 by BigJohnT
Yes, take a look in the motion and halui at the bottom of this page.
Some tool change info here:
www.linuxcnc.org/docview/html//config_ini_config.html#sub:[EMCIO]-Section
Last edit: 14 Jan 2010 18:44 by BigJohnT.
Time to create page: 0.143 seconds
