anyone running a probotix rf breakout
- tjfisher
- Rick G
- Thank you received: 155
Take a look here...
linuxcnc.org/docs/html/config_stepconf.h...sec:Axis-Travel-Home
Rick G
- tjfisher
- tjfisher
- Thank you received: 4967
Ok tryed to invert that didn't work
It has to. The home switch can't be both on and off all the time..
What did you invert, and where?
- tjfisher
In the pin settings and it's wired like this www.probotix.com/diagrams/4-Axis_ProboStep_wiring_diagram.pdf
Can you start up Halmeter (in the "Machine" menu of Axis) and see what the limit switch inputs are doing?
- tjfisher
ok will do what am i looking for ? last time i opened that it was a long list
axis.N.limit-sw-in I think.
- Rick G
Try...
Machine
Show Hal configuration
pins
Axis
0 (for x axis)
or
1 (for y axis)
or
2 (for z axis) etc.
Select the tab "Watch"
look for
neg-lim-sw-in
pos-lim-sw-in
Now toggle your limit switch by hand and check to make sure that there is a response.
Rick G
