× Forum Header
anyone running a probotix rf breakout
10 Dec 2011 15:11 #15528 by tjfisher
anyone running a probotix rf breakout was created by tjfisher
ok so i got all the limits and home wired and i thought set in the wizard but every time i get a message' joint 0 on limit switch error" does anyone know where i messed up i have set the xyz to home and max limit pins 11 12 13 , with the limits in series both x then to the ground and board and so on . now when i manually trigger each limit the screen shows then come up but i can toggle the machine on in axis keeps giving mr the error .im pretty sure i have something wrong in the stepcon wizard
10 Dec 2011 19:21 #15533 by Rick G
Replied by Rick G on topic Re:anyone running a probotix rf breakout
Have you tried inverting the signal?
Take a look here...
linuxcnc.org/docs/html/config_stepconf.h...sec:Axis-Travel-Home
Rick G
10 Dec 2011 20:18 #15534 by tjfisher
Replied by tjfisher on topic Re:anyone running a probotix rf breakout
I'Il have to try that tonight. I read threw that whole section and missed the invert
11 Dec 2011 01:14 #15540 by tjfisher
Ok tryed to invert that didn't work :-(
11 Dec 2011 01:37 #15542 by andypugh
Replied by andypugh on topic Re:anyone running a probotix rf breakout
It has to. The home switch can't be both on and off all the time..
What did you invert, and where?
11 Dec 2011 13:06 #15547 by tjfisher
In the pin settings and it's wired like this www.probotix.com/diagrams/4-Axis_ProboStep_wiring_diagram.pdf
11 Dec 2011 15:24 #15549 by andypugh
Can you start up Halmeter (in the "Machine" menu of Axis) and see what the limit switch inputs are doing?
11 Dec 2011 22:49 #15567 by tjfisher
ok will do what am i looking for ? last time i opened that it was a long list
11 Dec 2011 23:04 #15568 by andypugh
axis.N.limit-sw-in I think.
12 Dec 2011 09:41 #15584 by Rick G
Try...
Machine
Show Hal configuration
pins
Axis
0 (for x axis)
or
1 (for y axis)
or
2 (for z axis) etc.
Select the tab "Watch"
look for
neg-lim-sw-in
pos-lim-sw-in
Now toggle your limit switch by hand and check to make sure that there is a response.
Rick G
Time to create page: 0.078 seconds
