Forum Header
stepconf error. help
- Beniamin
13 Jan 2012 23:05 #16746
by Beniamin
stepconf error. help was created by Beniamin
Stepconf encountered an error. The following information may be useful in troubleshooting:
File "/usr/bin/stepconf", line 1915, in update_axis_params
halrun.flush()
IOError: [Errno 32] Broken pipe
halrun.flush()
- Thank you received: 2162
14 Jan 2012 08:08 #16757
Replied by cmorley on topic Re:stepconf error. help
If this error happens consistently then run stepconf from a terminal.
In the terminal it will show the underlying HAL error.
What version of EMC are you using?
You must have tried using motor testing / tuning ?
- Beniamin
14 Jan 2012 15:49 #16767
by Beniamin
Replied by Beniamin on topic Re:stepconf error. help
i run stepconf wizard from teminal and after that when i open emc2 i get this error:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/cnc/emc2/configs/ViperaCNC'
Machine configuration file is 'ViperaCNC.ini'
INIFILE=/home/cnc/emc2/configs/ViperaCNC/ViperaCNC.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=2035
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 File exists
2035
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 505.079644] I-pipe: Domain RTAI registered.
[ 505.079655] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 505.079659] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 505.079667] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 505.079671] PIPELINE layers:
[ 505.079675] e0601e20 9ac15d93 RTAI 200
[ 505.079678] c085cb20 0 Linux 100
[ 505.143135] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 505.143400] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 505.143408] RTAI[sched]: hard timer type/freq = APIC/6244649(Hz); default timing: periodic; linear timed lists.
[ 505.143413] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1398690000 hz.
[ 505.143417] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 505.143605] RTAI[usi]: enabled.
[ 505.261256] RTAI[math]: loaded.
[ 505.350842] config string '0x378'
[ 540.950441] RTAI[math]: unloaded.
[ 541.019888] SCHED releases registered named ALIEN RTGLBH
[ 541.033192] RTAI[malloc]: unloaded.
[ 541.132017] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 541.137530] I-pipe: Domain RTAI unregistered.
[ 541.137544] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.6
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Cleanup done
2035
- Beniamin
14 Jan 2012 15:54 #16768
by Beniamin
now i've got the error
/usr/bin/stepconf:24: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import md5
/usr/bin/stepconf:1156: Warning: g_path_get_dirname: assertion `file_name != NULL' failed
self.xml = gtk.glade.xml_new_from_buffer(doc, len(doc), domain="axis")
/usr/bin/stepconf:1156: GtkWarning: gdk_pixbuf_new_from_file: assertion `filename != NULL' failed
/usr/bin/stepconf:1156: Warning: g_object_unref: assertion `G_IS_OBJECT (object)' failed
/usr/bin/stepconf:1156: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
/usr/bin/stepconf:2115: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
widgets.testvel.set_range(0, maxvel)
/usr/bin/stepconf:2116: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
widgets.testacc.set_range(1, 100000)
/usr/bin/stepconf:2117: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
widgets.testamplitude.set_range(0, 1000)
Realtime already running. Use 'halrun -U' to stop existing realtime session.
import md5
- BigJohnT
- Thank you received: 1176
14 Jan 2012 17:03 #16770
by BigJohnT
Replied by BigJohnT on topic Re:stepconf error. help
Beniamin wrote:
Halrun is already running and was not shut down, open a terminal window and say
to close halrun.
halrun -U
to close halrun.
- Thank you received: 4994
15 Jan 2012 00:00 #16778
Replied by andypugh on topic Re:stepconf error. help
BigJohnT wrote:
However, I normally get it when I have made serious coding error in a realtime module, so it is certainly worth trying in more conventional situations.
I have found that to work only rarely, and I generally have to restart the PC at that point.Halrun is already running and was not shut down, open a terminal window and say
halrun -U
15 Jan 2012 02:19 #16784
With stepconf HAL errors, halrun -U works almost every time.
after that command run stepconf again from a terminal and if it errors note the error message.
It seems as if you realtime system isn't loading properly.
Did you just get some Ubuntu updates recently?
it could be that the realtime kernel isn't automatically loading anymore.
