Forum Header
"Test this axis/Run", and a limit switch
- grey1beard
30 Jan 2010 15:56 #1699
by grey1beard
"Test this axis/Run", and a limit switch was created by grey1beard
When using the "Test this axis" window, and the "Run" command, does operating the limit switch stop the motor running ?
In other words can I use this to find the correct settings for the limit switch for each axis ?
At the moment, it has no effect, and I don't know if it's because the setting in the parallel port window is incorrect, or if I have another problem elsewhere.
__________________
"It's like doing jigsaw puzzles in the dark"
__________________
- BigJohnT
- Thank you received: 1176
01 Feb 2010 12:01 #1719
by BigJohnT
Replied by BigJohnT on topic Re:"Test this axis/Run", and a limit switch
I'm pretty sure that the limit switches have no effect when testing from Stepconf Wizard.
- grey1beard
01 Feb 2010 12:21 #1722
by grey1beard
Replied by grey1beard on topic Re: Testing, with limit switches
Thanks John, you have confirmed my suspicions and that of another on cnczone.
Regards
Regards
Time to create page: 0.103 seconds
